Scale RC Helicopters Discuss scale helis, and modifications to pod and boom helis that make them scale.
5 Blade conversion and V Bar on Tubine Hughes
Reply
Old 05-02-2012, 03:48 AM
Springbok Flyer
Springbok Flyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 5 Blade conversion and V Bar on Tubine Hughes
Hi guys,
I have a Tubine AirStar Hughes 500e which I've been flying with a normal 2 blade head. Recently I acquired an Align 700E with a V Bar 5.2 system installed on the flybarless machine. Absolutely incredible stability and performance. As the V Bar system needs a pure swash setup, ie. three servos for pitch, I am thinking about converting my Hughes to 5 blades an installing the V Bar system.
Has anyone one done this on a multi blade (scale) Tubine heli?
Thanks for your comments.
Cheers,
Jan
Springbok Flyer is offline
Old 05-13-2012, 01:45 AM
modtron
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 5 Blade conversion and V Bar on Tubine Hughes
Jan,
3 servo ccpm conversion on the JetCat mechanics is very simple - pm me your email address and I'll send some pictures over.
Your biggest change will be that your JetCat system will need to be altered - the gearing is correct for 2 blade but not for multi.
You are currently running 1280 head speed and you will need to get it changed to a maximum of 998 - simple gear conversion at JetCat.
I would also suggest have ing the Twin Gear drive fitted at the same time to spread the increased loading - normally at no charge.
Again, send me a pm if you need more detailsof the changes.
modtron
Oxford UK
modtron is online now
