Chinook scale build
#52
RE: Chinook scale build
baurwin, There was a problem with the differential pitch, hopfully I have sorted to problem, I will do a few more test flights then ill put its clothes on. Just need to make sure everything is working 100%
#53
baurwin just put us on to this thread - greetings from Perth btw. Excellent job with the Chinook. As Eddie says - now looking froward to seeing it with the fuselage on. Well done.
#54
Thank you Jon6565, hopfully if all goes well, the next video will be fully clothed, I have been working on the fuse along with the mechanics, so im looking forward to it as well
I'll keep you posted.
#55
[img][/img][img][/img][img][/img] a little more progress on the fuse, still have to make turbines[:@]. I have also fitted the strobe to the rear tower, and will start on the nav lights.
#57
#58
[img][/img][img][/img] Pics of the formation lights off and on. Still have to add the nav lights and possibly the ngv compatible lights.
#60
[img][/img][img][/img][img][/img] More pics, the nav lights. Hopfully soon I will do some more testing on the mechanics after I add the govenor.
#62
I have been thinking of going electric for a more scale feel, and more importaintly less vibration. Anyone have ideas on suitable brushless motors and ESC that will do the job? The Align 90 flies the machine great but I could do without the noise, oil smoke, and vibration Converting to electric will be very easy, But finding suitable equipment is my prob.
#64
I'm flying a 30+ lb, 7-foot long electric Sikorsky S-76C+. You can get what you need from Sandy at www.v-eastonline.com . Call him.
I'm running a proprietary 8hp outrunner with a Kontronik Power Jazz 63 ESC and two 6S, 10,500mAh packs from MaxAmps.com. 1,000mm blades (aluminum).
Go electric; especially on a tandem. I had the Hirobo CH-46 and it flew fine, but vibrations and smoke ruined the scale effect.
Or...go turbine!
Or...go turbine!
ORIGINAL: tjmackey
#65
Thanks mkranitz, I have made the decision to go electric, I have found some equipment That should match the .90 I am currently using, And ill be using 4 x 5000mAh 5s packs to produce a 10,000 mAh 10s.
#66
Sounds good. Contact Cliff Preston at MaxAmps and tell him I sent you. He can hook you up with either 4 cells or two 10amp 5S packs (easier to manage and charge).
michael
michael
#69
I agree BarracudaHockey, oil smoke and noise is not the best for scale models. I think electric is the next best thing to turbines. The only downfall is you don't get the sweet smell of burnt jetA1[&o]
#71
Yes I have, Alexdrift
Hopfully I will receive them soon, I have also ordered new pullies to adjust the gear ratio to run at the motors rated output rpm. The convertion should go smooth However i'll have to make a longer shaft for the motor so I can use the pilot bearing on the other side of the pully
#72
Motor and speedy still not here[&o] so no more progress, however I am still working on the detail for the fuse. Will post pics soon.
#74
Well I've been waiting so long I decided to start building a large brushless myself just for fun here are some pics of the stator, endshields, and the rotating yoke. The stator is a 12 tooth and I will be running 16 magnet poles.[img][/img][img][/img][img][/img]
