rascal not running good.
RE: rascal not running good.
Have you adjusted far from factory settings? If not what altidude to you plan to run your Rascal at. High or low ? Has your Rascal ever been running right ? or is it new from the box ? Did you do a proper break in ? Does it have the same glow plug in it when you did the break-in. If not what's the condition of the one that's in there now. Without seeing it myself, I need to know more information about your engine, then we can figure out what is going on with it. [sm=50_50.gif]
Elven Wizard
Elven Wizard
ORIGINAL: elven wizard
Elven Wizard
Elven Wizard
It is so important that you not over lean the engine. Having it run slightly rich is a safer bet. Did you do engine break in by the book? Can you tell me what your glow plug looks like at the end of it, the outer coloring of the glow plug. Is the coil wire broken ?
Elven Wizard
Elven Wizard
Elven Wizard
Elven Wizard
update: passes pinch test 3 secs with quite a bit of rise in rpm's"does this mean lsn is still to rich,but it might balance out as i lean the hsn right?"
idle rises and falls a touch "could it be i need hotter glow plug"
its still hard to start how come? sometimes it takes about 20 or so pulls.ive watched a few vids showing how to correctly prime and im doing it right whats wrong?
Start all over. put a new glow plug in. Turn the settings back to factory. Re-start. Do a few runs making sure the engine is warmed up. While the engine is running turn the high speed mixture in slight increments to lean. and test. If there is still a problem your carb could have a air leak.
Elven Wizard
Elven Wizard
you know what mate i thought it might be a leak when it stops raining here in westmidlands i will go back to stock settings then we can go from there ok.
update: i've got my new glow plug in it is a medium running on 16% fuel.I have turned my hsn and lsn to stock "hsn between 2 and 4 1/2 turns and lsn 4 1/4 to 3 turns. to get the car to start i had to adjust the hsn to 2 1/4 turns and lsn 4 turns.The car is still a pain to start though.where we go from here elv?and cheers for the help.btw the wire on the plug is pretty dark and theres quite a bit of fuel on there.
