Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Navy-Curtiss NC-4
Old 09-29-2010, 10:58 AM
cas
Default Navy-Curtiss NC-4
I am looking for plans for a Navy-Curtiss NC-4. Any help. Thanks
Tim
Old 09-29-2010, 12:04 PM
Laird SS
Default RE: Navy-Curtiss NC-4
You might try the Naval Aviation Museum at NAS Pensacola. They have the original on display (or at least they did).
Old 09-29-2010, 01:45 PM
cas
Old 09-29-2010, 06:23 PM
CoosBayLumber
I think the NC-4 has been done to death. A friend of mine has a kit (in metal divided box) that was produced in late 1920's with a plan, and I know it has been done numerous times thereafter.
You only then need to match plan to your ability for there are many.
Wm.
Old 09-29-2010, 06:27 PM
cas
Wm, do you know where I can get these plans?
Tim
Old 09-30-2010, 09:08 AM
CoosBayLumber
ORIGINAL: cas
Tim
Tim
As mentioned, I think the kit was given to my friend via Vic Cunningham of RCM when he operated a small antique hobby shop in Pomona Calif. a few years ago. It was a rubber powered NC-4 out of the late 1920's. The box had a few missing parts out of the individual named compartments, and the replacement parts were made of balsa, for the originals were of bamboo and other light hardwoods, as balsa was not generally used yet in the era. The plans (two sets folded up) were off some Van Dykes (I assume as they had a lot of blue upon them), and run through a wet processs duplicating machine. Has been three years (or more) since I investigated the kit now.
Although considered a Giant Scale then, it is average to small today. I would suggest you use one of the more contemporary sources for building prints.
Wm.
Old 09-30-2010, 09:33 AM
cas
Thanks agian for the info.
Tim
Old 09-30-2010, 10:00 AM
scale only 4 me
My Feedback: (158)
scale only 4 me's Avatar
ORIGINAL: cas
Tim
AMA Plans Services has 4-5 sets, most are small Free flight/control line, but one is a 54" span that could be adapted to r/c
search the "C"s for Curtis, and the "N"s for NC-4
Many are "Kit" plans not scratch building plans though
good luck
Old 09-30-2010, 12:23 PM
Avaiojet
Downloaded this 3-view on line.
Hope it helps.
