Cad Drawings
RE: Cad Drawings
Look for "blueprint" services in your local phone book. If that doesn't work check for "drafting supplies" or the more correct spelling "draughting supplies". One of these will point you to shops that will have plotters to do paper copies of your plans. I'd suggest you get the master done on vellum or similar "tracing paper" and then you can get cheap black line prints run off from the master. If you do this by far the best and sharpest black line prints come from mirror image masters that put the inked side next to the blackline paper.
QC, CANADA
RE: Cad Drawings
ORIGINAL: longdan
The other thing to do is download a program called PDF Creator, and turn them into a PDF. Then just about any copy shop will be able to do it.
David.
