V-Tail surface area.
UT
What % of the total area of Horiz Stab and the Vert Stab on a conventional tail model would you want to make the two surfaces to convert it to a 110 degree V-Tail?
RE: V-Tail surface area.
Lots of conjecture, very little theory or actual practice when you ask modelers about V-tails.
Here is an old thread on the subject:
http://www.rcuniverse.com/forum/m_14..._1/key_/tm.htm
Forget projected area. 120 degrees works pretty well for most sport designs, but for the record, Beech used 118 degrees.
I built a Spirit sailplane and used 110 degrees. I combined the total tail area to make the tailfeathers. Worked like a dream! The aerodynamically ideal situation would be and inverted 'V'. The roll coupling would be to advantage.
Here's a pretty good write up of the topic but has a bit of math with it.
http://www.djaerotech.com/dj_askjd/d...ailvolumn.html
The angle of 110 comes up a lot but the angle is not cast in concrete by any means. In actuallity you look to get the amount of stabilizer and fin area needed and let the angle float to what it may. But generally it'll be not far off from 110. But let that go and aim for getting the right areas instead of locking yourself down to a given V angle.
