Aerodynamic Balance for Rudder
WY
I remember running across a site a few years ago that had some calculations for the aerodyamic balance for a rudder. I searched again since I now need some help, but couldn't find it.
Does anyone have any hints as to how large to make it, how much to weight it, or do I go for the "trial and error" or "copy something that works" methods.
RE: Aerodynamic Balance for Rudder
balaced tails usualy dont use weights,,thru,,"aerodynamic",,,a good example wood be the tails on a j-3 cub compared to the super cub,,,,i owned a clip wing cub powered with an o-200,,,,it had balnced tails,,,it was very light on ther controls. it also had super cub flaps built into the wings. it had to be registered in the experimental catigory.
Usually, do not exceed 10% of the area in front of the hinge line. And, yes, you can also obtain static or mass balance by weighting this forward portion so there is a much mass (weight) forward of the hinge line is there is behind it. This mass balance is much more effective on elevators and ailerons though instead of rudders; especially useful as it takes the strain off the servos caused by high G landings or violent maneuvers.
