jpg to dxf to dat devfus 2.0
Hi All,
I have a jpg of the Caudron C460 wing profile and I have no problems converting that to a dxf (Redraw).
OK I have down loaded Cadworks 3 trial because it has a dxf to Dat converter. Saved it as a DAT (File size 0K ?Strange?)
Tried to load it into Devfus but it wasn't accepted.
Is there a easier way?
Prboz
Prboz
RE: jpg to dxf to dat devfus 2.0
I have had a quick look at it but seemed to be getting noware so put it aside. I may have to have another go at it.
Prboz
Prboz
Prpoz,
Ok I can see your airfoil.
Symetrical.
Now, exactly what do you want to do with it? What is your goal?
Cut ribs, build a non tapered wing, a tapered wing??
Is that the tip airfoil also?
Symetrical.
ORIGINAL: Prboz
Here it is.
Prboz
Here it is.
Prboz
Here's the airfoil in TXT format. Arbitrary size.
email me at [email protected] for the .dxf and .dat files
Bob
It is the root of the wing and the chord is 510mm long.
I want to use it in DEVFUS for the wing slot and need a .dat file to insert. The Indice is 2 deg.
Prboz
Prboz
