Go Back  RCU Forums > RC Airplanes > Scratch Building, Aircraft Design, 3D/CAD
Reload this Page >
5/32 main landing gear - load capacity??
Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Old 07-28-2011, 05:57 PM
GarySS
My Feedback: (13)
Default 5/32 main landing gear - load capacity??
This is scratch building in a way..........I want to convert an ARF tricycle geared 5 pound model to a tail dragger. Its stock wire gear is 1/8 diameter. I can bend a 5/32 main gear set and add a tail wheel. It is a 5 pounder with a 59" span wing. Would this be too "springy"? I've used 5/32 in about a 4 pounder, but on a larger 5 pounder what would be the result? I want some stiffness.
Thanx for any opinions!.
Old 07-28-2011, 06:49 PM
Campgems
Default RE: 5/32 main landing gear - load capacity??
If you want some stiffness and a landing gear that will take a beating without bending out of shape, go with this one. http://www3.towerhobbies.com/cgi-bin...&I=LXNM65&P=ML
I've used it on planes from a 40 size stick to a Super Aeromaster, and a Four Star 60 with a Mag 91's. It is a landing gear that will outlast many planes, and it will prevent damage to them with is spring. Couple it with a pair of axles.
http://www3.towerhobbies.com/cgi-bin...?&I=LXD824&P=Mand your wheels, and you are good to go. Mount to a stout landing gear mount with four #10x32 nylon screws and even if you get ugly on a landing and rip the LG off, four new screws and you are ready to fly in a few minutes.
You can paint them to your color scheme, The don't bend. They may break, but with all the damage I've done over the last six years, I've not damaged one of them, and I hold the club record for the worst damage to a plane.
Don.
Old 07-28-2011, 07:20 PM
All Day Dan
All Day Dan's Avatar
These guys will make anything for you. Dan.
http://tntlandinggear.com/
Old 07-29-2011, 05:11 AM
Edwin
5/32" should work. Sounds like typical trainer size.
Edwin
Old 07-29-2011, 06:58 AM
GarySS
My Feedback: (13)
Thanks for the replies. The Dubro unit looks tempting, but I think I will bend a set of 5/32s to try at first.
Old 08-01-2011, 06:20 AM
CanDo
It also depends on what type of aluminum you are using and the dimensions of the gear. My 6 lb plane has 1/8" aluminum gear, 5/32" should work fine. BTW, Campgems idea of using nylon bolts to mount the gear is a good idea in case you happen to make a really hard landing.
Old 08-01-2011, 06:25 AM
LesUyeda
Banned
"5/32 main landing gear - load capacity?? "
Depends on how well you can land:-))))))))))))
Les
Old 08-01-2011, 06:39 AM
Bundubasher
Bundubasher's Avatar
Bending rods i.e. "piano wire" can be tricky. You need to heat and bend it, then temper it again - if not done right the rods will bend too easy or could be brittle and crack ipo bending.
Old 08-01-2011, 10:51 AM
aerowoof
no need if you have a master bender.they work great but are no longer made K&S made a similar tool that may still be available but heard they have problem.
Old 08-01-2011, 11:12 AM
Edwin
I used to bend up to 5/32" in my vice with a hammer. Never did any coils. 3/16" needs to be bent carefully though. Cant be too tight in the radius or it will crack like was said above. Never did any tempering on the small stuff (5/32 or smaller).
Edwin
