Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
31% Fokker Dr-1 Scratch Build
Reply
Old 10-26-2012, 08:37 AM
  #76
lazyace
lazyace's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: 31% Fokker Dr-1 Scratch Build
nice and neet , I opted for the solid gear , have it on my 1/3 pup seems to be OK , turning cold and rainy here tonight
lazyace is offline
Old 10-26-2012, 06:43 PM
  #77
rcwarbirdbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Will I got the undercarriage complete, still need to make the wood strut covers over thegear strut wire, and now start painting some of thecrosses on.
ID:	1815125   Click image for larger version
ID:	1815126   Click image for larger version
rcwarbirdbuilder is offline
Old 10-27-2012, 09:31 AM
  #78
rcwarbirdbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My hands are to shaky without maskingtape to paint this...
ID:	1815286   Click image for larger version
ID:	1815287   Click image for larger version
Old 11-01-2012, 08:21 AM
  #79
rcwarbirdbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Painting the details continues...
ID:	1816621   Click image for larger version
Old 11-02-2012, 03:03 AM
  #80
lazyace
lazyace's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
looking real good , when's the first flight ?
lazyace is offline
Old 11-02-2012, 12:40 PM
  #81
rcwarbirdbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just to dang cold for me to go outside and set this airplane up for flight, unless we get a warm snap in the weather... otherwise looks like I well be doing more detail work on it.
ID:	1816892   Click image for larger version
Old 11-03-2012, 12:34 PM
  #82
rcwarbirdbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have the fiberglass cowl detailed and painted and the dummy air intake tube stubs installed behind the cowl on the fuselage. I like using the rubber backed washer under the screws spaced 3" appart to hold the cowl. Balsa USA sells the neat prop washers.
ID:	1817207   Click image for larger version
Old 11-04-2012, 08:47 AM
  #83
rcwarbirdbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is what it is looking like, the next step for me to get it closer to fly is to balance the airplane.
ID:	1817522   Click image for larger version
ID:	1817523   Click image for larger version
ID:	1817524   Click image for larger version
Old 11-04-2012, 11:34 AM
  #84
lazyace
lazyace's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what no guns ?
lazyace is offline
Old 11-05-2012, 02:14 PM
  #85
rcwarbirdbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got to get some guns yet, along with Ace of Iron pilot and some leather trim around the cockpit opening. Still have more work to do on covering the wire wing and geare struts with wood struts, also need to make the wheel gear wing.
Old 11-06-2012, 08:22 AM
  #86
rcwarbirdbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I took pine about 1" wide and grooved it 1/4" on the back, so it can be slipped over the wire struts for a better appearance.
Old 11-15-2012, 08:38 AM
  #87
rcwarbirdbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am using some goop to secure the trim around the cockpit opening..
ID:	1820511   Click image for larger version
Old 11-16-2012, 08:14 PM
  #88
rcwarbirdbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The weather was not bad today so I got the first flight in before the sun went down, seems to fly good, airlon trim was dead on, elevator needed some down trim which is typical on most of these old timers. Now I can finish the detail on the dash, got a 1/3 Ace of Iron pilot on order, and need to get couple machine guns. http://www.youtube.com/watch?v=tCBrBlxSHOs
ID:	1821092   Click image for larger version
ID:	1821093   Click image for larger version
Old 11-17-2012, 03:37 AM
  #89
lazyace
lazyace's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
hi george looks real good in the air. Do you think my g-62 has the power for it to fly good ? started to cover it yasterday lots of mat'l
lazyace is offline
Old 11-17-2012, 04:42 AM
  #90
rcwarbirdbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Charlie, you know I had planed on using a G-62 when I started this project, but ended up installing a Q-75 becuase I got a good deal on couple larger used engines.. My impression after I made the first flight was that I did not need the Q-75 in it after all.. That is my friend making the second flight while I worked the camera, he likes it with the Quadra 75,, the big thing is that with a G-62 it would be hard to put it through all the areobatic manuvers he likes to fly, like the rolls without loosing altitude.. I think it well be ok either way, keep us all posted on which way you go, George.
Old 11-23-2012, 09:42 AM
  #91
rcwarbirdbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Getting Manfred the pilot from ACE of Iron prepped to fit into the cockpit of the DR-1...
Old 11-23-2012, 03:04 PM
  #92
rcwarbirdbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got a new 24x10 prop I picked upand the pilot painted and installed today..
ID:	1823118   Click image for larger version
ID:	1823119   Click image for larger version
Old 11-26-2012, 09:13 AM
  #93
rcwarbirdbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I got two spandau 1/3 size machine gun kits from BalsaUSA, pre painted the barrel inside black, than rolled it and glued the seam to make a tube has to be the most difficult part of the assembly.
Old 11-26-2012, 11:22 AM
  #94
lazyace
lazyace's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
a little flimsy for 32.00 I think
lazyace is offline
Old 11-26-2012, 12:52 PM
  #95
rcwarbirdbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That is what I am thinking Charlie, not $32, I got billed $39 each, not shure what it was with postage, well over $70, threw the bill away in the trash quick so I would not be reminded, sure looks like inflation is taking hold of prices and the wages keep going down for new hires..
Old 11-28-2012, 10:18 AM
  #96
rcwarbirdbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok, this is it, the guns are ready to mount..
Old 12-02-2012, 11:31 AM
  #97
rcwarbirdbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Put a little more lead in the front to make up for the added weight of the pilot and guns...
ID:	1825764   Click image for larger version
ID:	1825765   Click image for larger version
ID:	1825766   Click image for larger version
ID:	1825767   Click image for larger version
Old 12-02-2012, 03:45 PM
  #98
lazyace
lazyace's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
looks real nice with guns & pilot , still covering wings
lazyace is offline
Old 01-14-2013, 04:06 AM
  #99
lazyace
lazyace's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
george
sneeeek peeeek almost done if pics upload
ID:	1840253   Click image for larger version
lazyace is offline
Old 01-14-2013, 05:44 AM
  #100
rcwarbirdbuilder
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
lazyace, nothing lazy about that strut detailed on the upper part of the wing strut, L@@king good, what engine did you go with and when is the maiden flight scheduled for? George.
Reply
Display Modes
