31% Fokker Dr-1 Scratch Build
#103
My Feedback: (104)
RE: 31% Fokker Dr-1 Scratch Build
Charlie, i think that is about right, I have it balanced about 1/4" behind the point where the back landing gear wire strut attaches to the fuselage.
I took couple peice of wood and made a upside down tee shape, used one peice about 6"x8" as a base and another peice about 6"x10' and attached it at center of the base peice so it stands up, than I set the fuselage just behind the back landing gear on the peice standing up to check the balance at that point.
#104
My Feedback: (104)
The most recent picture of my DR-1, had it flying this week powered with a Quadra 75, flew great but it is near impossible not to get the wing tips to scrape the ground. I need to find someone looking to get rid of a Quadra 75 or a zenoah twin for my Nieuport 17.
#108
My Feedback: (104)
i DID GET A FEW FLIGHTS IN ON THE DR-1 LAST SUMMER, what I found is the J4 Cub has nothing on the DR-1 when it comes to doing ground loops and flipping over.. I am going to install a 3 axis gyro on it for this coming flying season... Has anyone have had experience with using a gyro on a big gasser?.
The airplane will unexpectedly do a ground loop and drop a wing tip on the ground and flip over easy, my plan was to use a hiding hold gyro on the airlon and rudder to keep the plane going straight and manageable on takeoffs and specially landings... What I found on hiding hold with the 3 gyros is that the servos do no want to go back to center on the same spot and is erratic.
So I am thinking of using the normal setting which momentary gives the control surfaces a short blip to counter the sudden airplane movement.
In the picture posted below started by buying a Hitec 3 axis gyro from Tower which is the one at the left top, I found it was not very reliable in fact I think there is something defective with it so I am not using it.. The next gyro I tried is a Hobby Eagle which I bought from Ebay, this one works and i like that it has 3 selectable functions, 1-it can be turned off, 2-it can be switched to hiding hold, 3- it can be selected in normal correction mode all from the transmitter, the bad thing like all 3 of them is it is erratic going back to zero on hiding hold mode and I would not trust it..
The third one I bought on Ebay is 3AXIS-A gyro, so far this one works the best in my bench trials, only thing is it has only 2 functions normal and off mode which can be switched from transmitter, a plus is that it has reversing switches on the unit to reverse the servos easily without getting into the gyro program, so i am thinking of installing this one in the DR-1.
#110
My Feedback: (104)
I don't see anything that sticks out that is different on your airplane looking at the pictures, looks like we both have the same wheels, only thing different I see is your field looks more level than the field I am flying off of, ours has low and high spots down the length, maybe that's it?.
I have the plane in the trailer now and planing to bring it down in the basement soon to set up the gyro on it. I am going to hook up the rudder and airlon through the gyro.
#111
My Feedback: (14)
My 1/3 tripe does the same thing.
