Go Back  RCU Forums > RC Airplanes > Scratch Building, Aircraft Design, 3D/CAD
Reload this Page >
looking for flying wing design...
Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Old 01-11-2012, 05:21 AM
Popriv
Default looking for flying wing design...
Trying to cobble something together using what I have..
I'm going to use home depot 2" thick foam cut with a hot wire....
Cut airfoils on each half then glue together.
Electric power. hitech -55 servos
Still searching for the right plan or I may just wing it....
steve
Old 01-11-2012, 08:14 AM
All Day Dan
All Day Dan's Avatar
Default RE: looking for flying wing design...
Steve, use this website to set the CG. Dan.
http://adamone.rchomepage.com/index5.htm
Old 01-11-2012, 10:06 AM
Popriv
ORIGINAL: All Day Dan
Thanks dan, a lot of info there.. that will help when I get to finding the CG...
Steve
Old 01-13-2012, 02:42 AM
guamflyer
Popriv,
I got to play around with a few flying wings and the fastest way I can think of is to check the MH airfoils and also the Eppler stuff. It also depends on what kind of wing you're interested in. the MH 60 was a pretty reliable foil and can also be fast.if memory seves me right ,the eppler 186 is good. if built light then you could thermal it. I fleww mostly slope and a few electrics. A while back I put together the Horten IIIb as electric but used the horten foil shown on plans. check out the UIUC site of Dr Selig..tons of foils. do a search on wings as the choices are a plenty...have fun.... guamflyer
Old 01-14-2012, 07:18 AM
jroth
My Feedback: (60)
jroth's Avatar
HI,
We fly the 40 sized Combat Gremlin with a 48 inch wingspan and a 24" electric version with an electric motor.
Let me know if this interests you.
john
