Radio setup for a canard?
OH
I am building a canard, Some tell me that I want a straight elevator and aileron setup. Others suggest That the elevators should be split and "assit" the aileron on the same side. Is there a need for putting the airlerons on different servos? I would like to split the elevators (two servos) and use a single aileron servo. I have a futaba 7C Radio.
Thank You,
Hernan L. Paulet
Quantity has a quality all on its own.
Thank You,
Hernan L. Paulet
OH
RE: Radio setup for a canard?
Do you have any mixing? or does each surface have its own servo due to the size of your aircraft. If i am making a right turn does the right elevator raise slighly to assit the right aileron? My current aircraft is a smaller 46 size and doesn't need two servos for aileron actuaction. Thanks.
Hernan
Hernan
