down thrust angel
RE: down thrust angel
It also depends on the CG location. Make it "stable" by moving the CG forward and you end up using up trim to compensate. And with the up trim the wing to tail isn't at 0-0 anymore and you find you need some downthrust. But if you set the CG back so the model is nearly or fully neutral for pitch stability then you'll find you need little or no downthrust.
If it's your intention to set it up that sensitive then by all means to for 0-0-0 for engine-wing-tail. If you find you need a slight shimming later then it's easy enough to add a sliver or two.
Guys, without wanting to sound seriously[8D].
Thus the standard bench set-up is:
Leaving aside right thrust (2.5-3.5 deg depending on engine/prop)
Engine: 0.5 negative (to counter the positive wing)
Lets talk about setting up an average, low wing aerobat.
There is no such thing as a 0-0-0 set up... apart from on the bench.
The moment to test fly your 0-0-0 model you'll have to add up elevator trim... thus lowering the stab
That's because a symetrical airfoil needs a positive incidence to generate lift (to fly), not much but it there, say about 0.5deg.
Thus you dial in the up trim (lower the stab) on your imaginative 0-0-0 model to give the aerofoil the desired incidence and what do you end up with?
Posítive engine, wing and stab incidence! NOT 0-0-0
There'll be those out there that say... "Mines 0-0-0 i don't add up evevator"
That'll be because you've got a rearward CG... thus the tail wieght is lowering the stab enabling the wing to establish a positive incidence.
The results are the same, positive incidence on all... not 0-0-0.
Wing: 0.5 positive (so it'll fly)
Stab: Zero.
Try it... it's a far more pure set-up than the imaginary 0-0-0. AKA +-+-+.
David
Just because you added trim to get a positive incidance ,the plane is still 0-0-0. Zero in relation to the plane it self is relitive at all angles.The addition of trim doesnot negate the true angle of its parent surface,the plane remains at 0-0-0. The plane being zero in flight attitude to the oncoming air is a differant subject.Kiwi4
The Cassutt in my Gallery is 0-0-0 with symmetrical airfoil. Thrust wing and stab on same datum line. It has a little right thrust for 'P' factor. Great flying model and tiny tailfeathers very effective because c.g. is at the rearmost limits.
