Landing gear bracing
What is the best method to brace a standard two-piece set of main gear? I was thinking of some sort of rod running from the axle lock nut to a mounting bolt on the opposite side X2, like the red lines in the picture. Or maybe something with springs?
RE: Landing gear bracing
The stouter you make the landing gear, the more likely you are to rip out the landing gear mounting from the fuselage on a hard landing.
Don
Don
True as that may be, that isn't really a helpful response. Iam interested in this too for my Pitts scratch-build. The gear is too springy and I am considering some wires.
Rigid bracing will snap in no time so you will need springs if you go that way.
I'd go with Dan's idea, new stiffer undercarriage, probably the quickest easiest, cheapest method. - John.
Like your drawing, Wire from wheel to wheel and from one mount bolt to the other with a rubberband or spring in the center like the J 3 CUB. It is more ridged ,but still has the bounce.
I see that TNT has the gear that I need, the only question I have is whether the gear is stronger or similar to the stock gear. Do they improve upon the stock gear, or just offer replacements?
impulse, I have ordered several custom gears from them and each one has been perfect. If the one they already have is made from thicker stock, then try it. If not, go to their custom order sheet and fill in the dimensions you need from the gear you have. Choose the next higher aluminum thickness than the one you have. It should be good enough. By the way, how much does you plane weigh? Dan.
impulse, use 3/16 inch aluminum at that weight. I mount my wheels and sometimes wheel pants to the gear with 1/4 inch bolts and the gear to the plane with 1/4 inch nylon bolts. You can see them in the attached image. I have no problem drilling the 1/4 inch diameter holes required with a 1/4 inch drill in a drill press. Ask the nice lady that answers the phone at TNT if they would do it. Dan.
Why not take some flat stock aluminum straight across from strut to strut 1/3 up from the wheels. benda 45 degree angle on each side drill it out and bolt it on. I have done this on wire gear as well with a peice of 1/4 inch brass tubing flattened 1 inch on both sides, bent to match the angle of the gearand soldered on to the wire. It works very well. HTH
To add my ideas to the mix, take a look at a J-3 Cub gear. It's very similar to the diagram that you drew in Post #1. Just add some compliance (O-Rings, etc) and see what you have. An even simpler idea is from the Hangar 9 J-3 Cub 40 LG at:
http://www.horizonhobby.com/products...cub-40-HAN4005
It's not all that exotic but it does have some compliance just from the wire. For the record, that black cylinders are just plastic decoration to simulate the bungees.
Just adding my $.02
Bob
Just adding my $.02
Bob
