Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Sheber Pitts S1S build
Reply
Old 09-06-2012, 12:30 PM
SplinteredProp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Sheber Pitts S1S build
Greetings,
New to the board, and would like to document this build here. If anyone is interested, they are welcome to follow along.
I just got my hands on a set of Andy Sheber 1/3 Pitts S1S plans, so the build is in it's infancy.
So far, I've only made a copy of the plans, cut up the copy to useable sizes, and have made a material list.
This will not be a fast build, since weekends are the only time I can dedicate to building.
Since it is my intention to post a pic with every post (except if answering a question), I will start off with a pic of the plans.
SplinteredProp is offline
Old 09-06-2012, 12:50 PM
john josey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Sheber Pitts S1S build
Hi There,
I built a 1/3 s1s from the toni clark kit a couple of years ago so i'm definatly interested in your build !
                   cheers
                          john
john josey is offline
Old 09-06-2012, 06:40 PM
smithcreek
smithcreek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking forward to this.
smithcreek is offline
Old 09-09-2012, 06:19 AM
SplinteredProp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This plan requires various elements to be laminated to curved shapes, the most complexbeing the horiz stab/elevator (hs/e).
SinceI've never attempted thismethod of construction before, this seemed like the logical place to start.
Pic 1: The plan.
Pic 2: Itracedthe inside line of the perimeter of the hs/e, cut out the pattern, and glued it to doubled up pieces of MDF, which Iscrewed together.
ID:	1799507   Click image for larger version
Old 09-09-2012, 06:21 AM
SplinteredProp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Pic 1: The pattern/template after being cut with a band saw and final shaped with a bench belt/disc sander.
Pic 2: I drilled 1" dia holes through the template while they were still screwed together - these will provide places for clamping. I then seperated the 2 template halves, placed packaging tape around the perimeter and screwed then to my workbench.
ID:	1799509   Click image for larger version
Old 09-09-2012, 06:28 AM
SplinteredProp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I needed a few balsa strips, so Ifashioned a bench mounted balsa stripper.
The plan calls for a final thickness of 5/16, but Icut these to 7/16 to allow me to sand out imperfections and uneven strips.
ID:	1799511   Click image for larger version
Old 09-09-2012, 06:38 AM
SplinteredProp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Isoaked the balsa strips for about an hour, then placed them, without glue, around the template. Iwanted to pre-shape the laminate strips before gluing. Ithought this would make the gluing process easier. That also explains the lack of wax paper under the template in the first pic.
After the laminate pieces dried, Iremoved them from the template, placed wax paper under the template, and began gluing the layers together.
Iglued a single layer at a time, allowing approx 30 minutes between layers, for a total of 6 layers, and let dry overnight.
The finished piece ended up being between 13/32 and 7/16 thick, allowing me enough material to sand to a finished 3/8 width.
Overall, I'm pleased with the finished result, considering Ihave never attempted this construction method before.
That's it for this weekend - Today is going to be spent watching football.
ID:	1799513   Click image for larger version
Old 09-15-2012, 03:50 PM
SplinteredProp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK, back to the shop...
The first thing Idid was to cut the HStab TE & Elev LE to the correct size, mark the hinge locations,add 5/16x3/8 backing to the hinge locations, drill them both at the same time on the drill press. Ithen inserted dowels in 4 of the 8 hinge holes to keep everything aligned. (Pic 1)
My shop helper (Pic 2)
ID:	1801472   Click image for larger version
Old 09-15-2012, 06:34 PM
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have the plans, cowl, pants, and canopy. Plan to start after the first of the year. So I am subscribed and learnin.
acerc is offline
Old 09-16-2012, 05:08 AM
SplinteredProp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ididn't like how little material there was for the hinges to grab ontoin the elevator, so Iadded more balsa. (Pic 1)
The almost finished stab/elev (pic 2)
ID:	1801578   Click image for larger version
Old 09-16-2012, 05:10 AM
SplinteredProp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rather than use block balsa in areas that require addidtional strength, Imade 3-ply balsa pywood...
ID:	1801580   Click image for larger version
Old 09-23-2012, 06:12 AM
SplinteredProp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I cut the Hstab/elev gussets out of 1/8" plywood on the scroll saw &sanded to fit (pic 1)
The finishedH stab/elev (pic 2)
ID:	1804024   Click image for larger version
Old 09-23-2012, 06:22 AM
SplinteredProp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I dislike sanding the edges of control surfaces since I feel as though I have little control - especially on this H stab/elev with everything being curved.
So I figured a shaping tool of some kind was needed and made on out of a piece of 1/2" PVC & some self-adhesive sandpaper.
ID:	1804027   Click image for larger version
Old 09-23-2012, 06:23 AM
SplinteredProp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The finished result after using the PVC sander & finishing with some 220 grit.
Old 09-23-2012, 06:26 AM
SplinteredProp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ithen cut the elevator away from the H stab, and rounded the elev LE the same way Idid the other edges.
Iwant to minimize the gap between the elevator & H stab, so in order to do that, Ineeded to make the TE of the H stab concave.
Another tool was needed, and this time a pencil & piece of sticky sandpaper was used.
Old 09-23-2012, 06:27 AM
SplinteredProp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The finished result.
ID:	1804031   Click image for larger version
Old 09-23-2012, 06:33 AM
SplinteredProp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Iwould love to hinge this thing before covering, but Iam unsure how Iwould do that....any tips would be greatly appreciated...
Old 10-09-2012, 10:51 AM
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
http://www3.towerhobbies.com/cgi-bin...?&I=LXES25&P=7   Might be helpfull
acerc is offline
Old 10-11-2012, 06:49 AM
SplinteredProp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, after a shop disaster which resulted in the destruction of the stab & elevator, I had to start from scratch & rebuild.
I took this opportunity to make some changes to the stab/elev. In my opinion they are improvements - things that I thought of after building the first stab/elev.
Pic 1 shows the new stab/elev.
Pic 2 shows 1/16" plywood inlays at the points where the flying wires will be attached. These should make a more stable area of attachement.
Pic 3 shows how I reinforced the leading edge of the stab with plywood gussets. I figured this couldn't hurt since this is one of the areas where the airplane is held during engine run-ups.
I also doubled up the balsa on the trailing edge of the stab & leading edge of the elevators to provide strength & a better gluing rea for the hinges.
ID:	1810254   Click image for larger version
ID:	1810255   Click image for larger version
Old 10-13-2012, 06:28 PM
R/C Art
R/C Art's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: acerc
I also have the same items but don't know when I will ever get to the actual build. I am subscribed, too.
R/C Art is offline
Old 10-14-2012, 05:21 AM
acerc
acerc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
SP did you give the above link a look in regard's to the hinging?
acerc is offline
Old 10-14-2012, 05:50 AM
R/C Art
R/C Art's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: SplinteredProp
Pic 2: I drilled 1'' dia holes through the template while they were still screwed together - these will provide places for clamping. I then seperated the 2 template halves, placed packaging tape around the perimeter and screwed then to my workbench.
I have laminated outlines on several projects over the years but never thought about drilling holes around the perimeter and using clamps. Sheer GENIUS! I will use this technique in the future for sure. (I have sent you a PM)
R/C Art is offline
Old 10-15-2012, 02:12 AM
SplinteredProp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: acerc
Yes Idid, thanks for the link. The hinge pockets are worth considering, but I'm not sure I'm going to go that route.
Old 10-15-2012, 02:14 AM
SplinteredProp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: R/C Art
Ican't take credit for being a genius. I've seen that method on this site and copied it. But it is a forehead-slapping type of an idea...
Old 10-15-2012, 06:38 AM
SplinteredProp
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, didn't get too much done this weekend, as I chose to spend a lot of time flying instead
I did work on the upper wing ribs, and in studying the plans, I really didn't like the spar arrangement as shown. In Pic 1, you can see where the main spars (1) are shown as 1/4" x 1/4" balsa, and not located at the thickest part of the rib.
I chose to add 3/8" x 1/4" basswood main spars as shown on my rib template in Pic 2 (1). A also decided to use 2 1/4" x 1/4" TE spars in lieu of the 1/4" x 1/2" spar drawn on the detail (2). I wasn't confident that I could cut accurate rectangular holes in the ribs.
I spray-glued the modified detail onto 1/8" plywood, and cut on the bandsaw. I then glued sandpaper onto the backside of the template to prevent it from moving while cutting the ribs.
ID:	1811497   Click image for larger version
Reply
Display Modes
