Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
laser cut ribs, what would you do?
Reply
Old 12-23-2012, 10:37 AM
kenh3497
kenh3497's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default laser cut ribs, what would you do?
I have a laser cut short kit with the wing ribs that are inconsistent in their cut. The wing has quite a bit if taper. The ribs do match the plans so I find the fault with the plans and not the kit cutter.
I'm considering cutting a foam wing but it needs to be grafted onto a ply center section that houses the retracts and attached to the fuse. When complete the wing is intended to be a 83inch span one piece wing. Here are some photos of the wing ribs.
ID:	1833130   Click image for larger version
ID:	1833131   Click image for larger version
ID:	1833132   Click image for larger version
ID:	1833133   Click image for larger version
kenh3497 is offline
Old 12-23-2012, 11:29 AM
limeybob
limeybob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: laser cut ribs, what would you do?
Which plans?
limeybob
limeybob is offline
Old 12-23-2012, 12:48 PM
longdan
longdan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Whats actually wrong with them?
longdan is offline
Old 12-23-2012, 01:26 PM
countilaw
countilaw's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Line the spar slots up straight and see what you get. From what your pictures show, I can't see anything wrong with them.
Frank
countilaw is offline
Old 12-24-2012, 07:45 PM
smithcreek
My Feedback: (25)
smithcreek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a friend that just built a Cessna 170 from some old plans he bought through AMA. He cut the ribs himself and when I saw them I figured he had really screwed up, they looked just like yours. Some flat bottom, so concave, some convex and virtually none of the spar notches lined up. While we were trying to piece it all together I took a look at the plans and turns out he had cut them exactly as shown on the plans, unfortunately the plans sucked. In the end, he's the kind of builder that doesn't really care and basically made the pieces go together whether they fit or not. If it was me I would have thrown them out, but once it's done I'm sure it will fly just fine.
smithcreek is offline
Old 12-26-2012, 08:24 AM
Bax
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The thing to do is to trial fit everything together and then custom-make pieces where the laser parts are bad. It's no big thing to fix a single wing rib or bulkhead. Many plans have discrepancies that show up because they were hand-drawn. You live with them and make new parts as needed that fit properly. Sometimes, you only have to sand/cut the existing part and you're done. Other times, you project what the part should be and make a new one. It's all part of plans building.
Bax is offline
Old 12-26-2012, 08:28 AM
pitts M 12
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I think that those ribs are quite good as it looks like they are cut with wing washout in mind at least in refrence to the cuts of the bottom surface. Do the plans mention wing washout?
JM
pitts M 12 is offline
Old 12-26-2012, 11:10 AM
kenh3497
kenh3497's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The wing was dry fit and there was issue with the size of the spar slots being to small. (good thing). The next issue was the location of the spar slots. Some were so badly misaligned as to leave a gap when the slot was enlarged to fit the spar location. After the dry fitting, a strait edge on top of the wing would rock and not lay flat touching all the ribs. With 17 ribs, how do you determine which are OK and which need replacing. The center section of the wing also had some of these same issues but they were minor and easily corrected as it is more or less without taper
Again, and I emphasize, it is not the fault of the kit cutter. The ribs match the plans well.
OH, the wing had 6 degrees of washout and 4 degrees of positive incidence if that helps.
Ken
kenh3497 is offline
Old 12-26-2012, 01:07 PM
FlyerInOKC
FlyerInOKC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What aircraft are you building?
FlyerInOKC is online now
Old 12-26-2012, 02:02 PM
kenh3497
kenh3497's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: FlyerInOKC
Zlin 526. It is a bit of an odd wing. The root is semi-symmetrical and the tip is under cambered.
kenh3497 is offline
Old 12-26-2012, 03:34 PM
All Day Dan
All Day Dan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ken, if you want to switch to a foam wing, flying foam.com can help. I have received about 20 of their wings in the 50cc size that were perfect. Dan.
All Day Dan is online now
Old 12-27-2012, 01:04 PM
FlyerInOKC
FlyerInOKC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Its a good looking airpane! If you look at my avatar you will see one of my ongoing projects. It has a bit of a tapper and then the tip ribs are cut to allow a 3/8" washout. The root rib is 17.75" and the tip is 4.75" long. Now that is a tapper!
Old 12-28-2012, 08:50 AM
Bax
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: kenh3497
Ken
If you project a straight line from the root rib to the tip rib, you can usually find the bad ribs. If there are too many that are high or low, then you build the wing and then use a long bar sander to true-up the ribs. Ribs that are undersized must be replaced. You also use a bar sander on good-quality kits, where the ribs need to be sanded smooth before covering or sheeting.
Bax is offline
Old 12-29-2012, 06:32 AM
kenh3497
kenh3497's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It seems there may be a fix in the works for these ribs. When the solution gets a little closer I'll post something. I'm not sure of the time table though.
Ken
kenh3497 is offline
Contact Us Archive Advertising Cookie Policy
