Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Profile engine mount
Reply
Old 12-29-2012, 03:51 AM
jp1961
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Profile engine mount
I'm making a profile plane that will have a 25cc converted Homelite engine. The fuselage will be a
sandwich of 5/32" plywood to 15/16" extruded polystyrene foam. I'm thinking of mounting the engine to the fuselage with 1.5" x 1/8" aluminum angle using 3 bolts (will also support the landing gear). The 1 1/8" dowels will be epoxied in between the plywood to support the engine. Will this be strong enough?
Jeff
jp1961 is offline
Old 12-29-2012, 06:27 AM
kenh3497
kenh3497's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Profile engine mount
If that engine is a vibrator I would double up on the ply at the nose to about 1/3 of the wing. From the canopy back it could be cut at an angle from the canopy to the wing saddle to save a bit of weight and help prevent stress risers. The dowels for the engine mount is a very good idea and an absolute must. Looks good so far. As a second thought you might consider solid wood all the way through in the engine area. Maybe somebody else will pipe in with better ideas than me.
Ken
kenh3497 is offline
Old 12-29-2012, 10:37 AM
jp1961
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I may add fiberglass cloth between the foam and plywood (just in the engine area). I could always add glass to the outside surface of the plywood as well.
Jeff
jp1961 is offline
Contact Us Archive Advertising Cookie Policy
