Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Velcro to hold wings on?
Reply
Old 01-23-2013, 02:08 PM
jp1961
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Velcro to hold wings on?
I'm thinking of using Velcro to hold the wings on my profile. The wings have a (very) snug fit on the aluminum joiner tube (1.250") and there is a 3/8" dowel to keep them from rotating. Being a gas plane there would be no problems with oil residue. The Velcro would be on the bottom of the wing, strips about 5 or so inches long (positioned from root to tip). The one side would be attached to the fuselage with wood screws. The other side of the Velcro would be epoxied to the wing (I don't trust the peel and apply type). Velcro doesn't vibrate loose and assembly at the field would be a snap. Again, thinking outside the box. Any thoughts, ideas?
Jeff
jp1961 is offline
Old 01-23-2013, 02:25 PM
countilaw
countilaw's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Velcro to hold wings on?
Go for it !! And send us the pictures of the results .
Frank
countilaw is offline
Old 01-23-2013, 02:34 PM
Live Wire
Live Wire's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Get back in the box
Live Wire is offline
Old 01-23-2013, 04:32 PM
N1EDM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Take pictures of the debris field before you pick up the pieces.... Somehow, I don't think this is a good idea....
Bob
N1EDM is offline
Old 01-23-2013, 09:49 PM
Campgems
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jeff, the velcro has good holding ability in the shear direction. The issue with it is that it gathers all kinds of crud over time and becomes less and less effective.
My concern is that over time, the air flow would tend to peal it off given the lint and crud thatit picks up in use.
Otherwise, it isn't much different than some of the "use once" tape I've seen used to hold glider wings together. Should work. Although a bit heaver than the tape.
Don
Campgems is offline
Old 01-23-2013, 10:57 PM
combatpigg
combatpigg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Olympic 650 glider was a 3 piece wing that used pins to plug the outer panels into the center section, then they [IIRC] recommended using electrical tape to seal the slight gap [seam] where the panels meet.
Actually, I'm not really sure if the instructions called out for taping the seams or not..it's been over 20 years. This was a 2 or 3 pound plane that flew at 25 mph.
For a big, powerful aerobatic model with a fast roll rate I would be a little bit nervous about the velcro.
combatpigg is offline
Old 01-24-2013, 07:56 AM
LesUyeda
Banned
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
" The issue with it is that it gathers all kinds of crud over time and becomes less and less effective. "
Valcro, otherwise known as "hook and loop" material. The "hooks" wear out, tear off, and loose their effectiveness.
Les
LesUyeda is offline
Old 01-24-2013, 08:11 AM
aspeed
aspeed's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Someone needs to come up with a better method than rubber bands and nylon screws.  Every time I use the screws and have a bad day, the pins in front of the wing wreck the fuselage former, and rubber bands are just unprofessional. I would check real close before using the velcro.  I always hold the wing firmly and shake it up and down real hard to see if the wing/fuselage pulls up or moves.  (Then add more rubber bands if it does. or in your case abort the idea)
aspeed is offline
Old 01-24-2013, 11:23 AM
ARUP
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Check out offerings from 'Iflytailies.com' or similar. They carry Graupner and other wing connectors that work well for BIG sailplanes that fly can faster than most powered airplanes. Otherwise a tab and thru bolt are the best options. My 1/4 DH-5 has scale connectors which consists of two connectors per wing that are bolted to top sides of wings at spar locations.
ARUP is offline
Old 01-24-2013, 11:50 AM
aspeed
aspeed's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Back in the last millenium I kind of remember a spring loaded pin that was pushed in from the back I think, and used the locating spring in front like the conventional way.  The spring was kind of like a ball point pen spring.  I can't remember much about it, it was the 70's man. Another more recent one had a slot in the wing so the wing would twist in a light crash.  Couldn't see the picture close enough to figure it out.
aspeed is offline
Old 01-24-2013, 12:44 PM
iron eagel
iron eagel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry using Velcro to hold the wings on is a bad idea, stick with something a lot less outside of the box.
iron eagel is offline
Old 01-24-2013, 01:22 PM
Rodney
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
For those using the peg or pin in the front former to hold the front of the wing on and then screws in the back: most use much to large a screw, usually 1/4-20's. These are much to large. On most planes, a 6-32 is more than ample. for 1/4 scale go to 8-32 nylons. Also make sure there is no gap between the wing and the point where the screw enters the fuselage. You want it a tight fit so that, if you hit on a wing tip the bolt(s) will shear easily. Having no gap aids in this shearing action. Without it, the bolt tends to bend and it takes much more force to break it if it is in tension which can cause the front pins to tear out the bulkhead they are inserted in.
Rodney is offline
Old 01-24-2013, 01:26 PM
Boomerang1
Boomerang1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Why not?
Like Don said velcro has lots of strength in shear, I use it all the time to hold batteries in
with a loop around the battery with plenty of overlap.
Maybe the answer is a seperate, loose velcro strap which loops through the (re enforced) wing
ribs, through the fuselage, back through the opposite wing with a large overlap on the bottom.
If the velcro gets a bit manky with age just replace it. - John.
Boomerang1 is offline
Old 01-24-2013, 06:27 PM
iron eagel
iron eagel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A big Gas aerobatic plane with the wings held on with Velcro really sounds a bit iffy to me.
I use Velcro doubled up to secure my batteries into planes but I personally would never use it for something structural.
Having dealt with full scale aircraft, I am a bit more conservative than most when it comes to how planes are held together.
Old 01-24-2013, 08:40 PM
ARUP
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are some examples.
ARUP is offline
Old 01-25-2013, 09:10 AM
aspeed
aspeed's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I saw the I fly tailies thing before too.  I guess here is the dumb question.  Doesn't that just hold the wing together, not on,   a regular top or bottom fuselage mount?  The Tailies snap thing too?
aspeed is offline
Old 01-25-2013, 04:29 PM
N1EDM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hmmmmm, I don't see jp1961 anywhere but in the 1st post. You don't suppose that this was a phishing expedition, do you???
N1EDM is offline
Contact Us Archive Advertising Cookie Policy
