Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
increasing wing area question
Reply
Old 01-26-2013, 10:45 PM
DESERT RATT
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default increasing wing area question
I have on my building board at this time a Tower Uproar kit.
I have two Magnum.30 4 strokes which I'm going touse for this endevour.
Will I have to or should Iincrease the wig span/area for better control?
The advertised specs are as follows,
Wingspan= 48"
Wing area=578 sq."
Length= 42"
Weight as a single engine= 3.5 to 4.lbs.
Thanks in advance because I have no idea how to figureand work with the numbers.
Ratt
DESERT RATT is offline
Old 01-27-2013, 07:48 AM
sensei
sensei's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: increasing wing area question
You have two choices, First choice, lighten the airframe to comp weight and hold the same wing loading. Second choice add only enough wing span area, and it is not going to be much to hold the same wing loading. Then again you could always just build as is, add two engines and have a little speed merchant, but that makes three choices doesn't it...
Bob
sensei is offline
Old 01-27-2013, 07:52 AM
All Day Dan
All Day Dan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ratt,
If you increase the wing area you will have to increase the area of the empennage proportionally or increase the length of the moment arm from the CG to the tail surfaces. Dan.
All Day Dan is offline
Old 01-27-2013, 08:42 AM
limeybob
limeybob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: All Day Dan
Ratt,
correct
Or you can move the C.G. forward a little, plane will be more nose heavy anyhow, so this will help
limeybob
limeybob is offline
Old 01-27-2013, 09:16 AM
iron eagel
iron eagel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: DESERT RATT
I have two Magnum .30 4 strokes which I'm going to use for this endevour.
Will I have to or should I increase the wig span/area for better control?
Wingspan= 48''
Wing area= 578 sq.''
Length= 42''
Thanks in advance because I have no idea how to figure and work with the numbers.
Ratt
First of all let me get this right, you are going to turn the uproar into a twin?
If so there are several things your going to need to do, this is how I would approach it.
Increase your wingspan to either 56 to 64 inches.
Enlarge your rudder and vertical stabilizer area as well as your horizontal stabilizer and elevators about the same 8-10% as you increase your wing area. (If you do this you won't have to change the length of the fuselage.) You want to put more of you increase in area to the vertical area to the rudder so you will have some chance of control in the case of an engine out.
iron eagel is offline
Old 01-30-2013, 09:35 PM
DESERT RATT
My Feedback: (7)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes, It's going to be a twin. Two Magnum 30 4-strokes.
Iam in the middle of extending the fuselage 3". I'll make the nose cone 4 or 4.5" long plus I will extend the elevator from 3.5 to 5" the rudder will be in proportion to the rest. I think Ican reasonably get the length from 42" to 47".
Thanks for your input!
Ratt
Contact Us Archive Advertising Cookie Policy
