Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
CG Calculation Differences
Reply
Old 02-23-2013, 07:00 PM
ron12901
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default CG Calculation Differences
Why is the Ideal CG so different between the Adamone and the Geistware calculators in the link at the the top of this forum? I put i the same wing/tail numbers and the Adamone Ideal CG at 15% statisc margin is 5.08 in. while the Gistware number is 5.49 in. My wing root is 17.25 in (tip 12.25); this seems to be a significanr difference. Which one should I use?
ron12901 is offline
Old 02-23-2013, 07:33 PM
All Day Dan
All Day Dan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: CG Calculation Differences
I've been using this one for years. It's right on with another method I use for a double check. Dan.
http://www.geistware.com/rcmodeling/cg_calc.htm#mac
All Day Dan is online now
Old 02-23-2013, 07:39 PM
All Day Dan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Also, you may have your static margin and percent MAC set wrong. Dan.
Old 02-23-2013, 08:44 PM
Thud_Driver
Thud_Driver's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Last year when I wanted to put together my own spreadsheet for Cg, I looked at a lot of different implementations.  What I noticed was that there are a couple of effectiveness/efficiency coefficients buried in the equations that each author has used as his best guess.  They tend to be slightly different between all of them and so you get different answers.  If you go look up sources, you will get opinions of what they ought to be based on aircraft configurations, experience, theory, etc.    So each author has chosen what he thinks fits model aircraft best.
I ended up using Adamone as my reference for crosschecks but they will all get you in the ballpark.  After that, you have to fly and test.
Thud_Driver is online now
Old 02-24-2013, 05:48 AM
karolh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Would be interesting to hear more views on this topic so hopefully more folks will chime in.
karolh is offline
Old 02-24-2013, 06:54 AM
Lnewqban
Lnewqban's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: karolh
I just verified both with different numbers and found out that the difference is in the location of the NP, which considers the moment introduced by the tail (it should be the same for both since it depends on tail area and fuse length).
Lnewqban is offline
Old 02-24-2013, 02:53 PM
Thud_Driver
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you look at Adamone's version, there is an entry for Stabilizer Efficiency.Viewing the source for the page around line 178 you can see the values applied for stab efficiency, i.e., .85 for Std, .65 for Low. Opinions vary about what value to use. A quick look at Geistware seems to indicate thathe uses .80 in his neutral point calculation.He also notes published references for his method.
In IE, go to the View menu and click on Source to see the code.
Old 02-24-2013, 05:24 PM
limeybob
limeybob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here's mine
try it out
limeybob
File Type: xls
limeybob is offline
Old 02-24-2013, 07:44 PM
All Day Dan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Limey, your Excel file does not open. Does RCU support .xls files? Dan.
Old 02-24-2013, 09:19 PM
limeybob
limeybob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
try, right click, save as link.
limeybob
limeybob is offline
Old 02-26-2013, 06:38 AM
ron12901
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Limeybob, I tried your worksheet and got a cg right in the middle of the adamore and geistware values with a 15% safety factor. Thanks for attachment, I will use it. What I like is that I can save a spreadsheet for each plane and always have it available for future reference. The links can'f be saved with the data.
ron12901 is offline
Old 02-26-2013, 06:44 AM
limeybob
limeybob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OK, glad you like it.
The neutral point is a tricky one, had to use three different formulae and average them.
limeybob
limeybob is offline
Old 02-26-2013, 09:40 AM
karolh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi LB,
I tried using your formula but could not understand what the terms Tail Root Leading Edge and Tail Root Trailing Edge refers to.
karolh is offline
Old 02-26-2013, 09:44 AM
limeybob
limeybob's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
dimensions "e" and "f" on the instruction page.
limeybob
limeybob is offline
Old 02-26-2013, 03:25 PM
karolh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
karolh is offline
Contact Us Archive Advertising Cookie Policy
