Dropped the wing removed some of the lower fuse that was damaged in a bad landing. Lost 50 grams in the process and the wheels which are no good at our field.
The angle of incidence remains the same as the plans. I'm hoping the lowering of the wing relative to the thrust line will reduce the nose up tendency with power.
If the wind ever stops I shall have a fly
