Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Steel tube fuselage
Reply
Old 02-28-2013, 10:45 AM
kchmn
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Steel tube fuselage
I am building a 1/4 scale Piper J-3 with a steel tube fuselage, I am wondering what the steel will do to radio reception? It is mostly 3/16 steel brakeline brazed together, weight not quite a pound heavier than a balsa built model.
I have heard a bunch of different stories and theories about how the radio will recieve. My antenna will be on the top of the fuse from the cabin top to tail fin.
Has anyone flown metal framed planes? and how do they perform? Thanks, Kirk
kchmn is offline
Old 02-28-2013, 06:58 PM
TFF
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Steel tube fuselage
What type of radio set up?
TFF is online now
Old 02-28-2013, 07:00 PM
invertmast
My Feedback: (22)
invertmast's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My buddy has been flying all metal airplanes for as long as he's been in the hobby (since the 80's). He's used 72mhz FM and PCM and 2.4ghz and hasn't had problems.
The open tube structure of the J-3 won't pose a problem, but a proper range check should be done of course
invertmast is offline
Old 02-28-2013, 11:56 PM
bogbeagle
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There was a brief fashion for microlight-type models, in my locale. These were fixed-wing, with open fuselages which were fabricated from piano wire. This was way before 2.4 GHz.
Never heard of any problems with radio equipment.
You could site the Rx in the wing, I suppose ... I'm assuming that this will be a wooden structure.
bogbeagle is offline
Old 03-01-2013, 06:47 AM
FlyerInOKC
FlyerInOKC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There ar a lot of scale guys using Flite Metal to cover their warbirds with no radio problems. They are skinning the aircraft with a layer of aluminum in a solid skin. Flite Metal did a lot of testing with internally mounted RXs. I think you don't have anything to worry about.
FlyerInOKC is offline
Old 03-01-2013, 07:30 AM
TFF
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is a kit http://www.paoloseverin.it/page79/page79.html
TFF is online now
Old 03-01-2013, 07:35 AM
FlyerInOKC
FlyerInOKC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice kit!
Old 03-03-2013, 02:47 PM
FliteMetal
FliteMetal's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I see no issue as long as the tubing is not loose generating spurious r/f.
FliteMetal is offline
Contact Us Archive Advertising Cookie Policy
