Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Flitetest.com Old Fogey 2 In Foam Board
Reply
Old 03-09-2013, 12:13 PM
nickatredbox
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Flitetest.com Old Fogey 2 In Foam Board
Due to the apparent poor performance of myCoroplast FogeyI have built a foam board one to see if it works better It Flys Fogey and Piper Cub
All finished
AUW 732 Grams
1000mAh Zippy Compact
Landing gear
All rubber bands ect ready to fly
My custom power pod
2210N 1000KvBrushless motor
Weight:45g
Shaft:3mm
Spec.
GWS9050 @3S
Max Amp: 11.2A
RPM/Min: 8700
Thrust: 740g
APC9x3.8 @2S
Max Amp: 6.5A
RPM/Min: 6260
Thrust: 405g
My Thrust Tests with a GWS 10X4.7 slow fly and a 2200mAh 3 cell
3.7 A 45 Watts 303 Grams
7.3 A 86 Watts 480 Grams
9.5 A 111 Watts 550 Grams
13.1 A 150 Watts 655 Grams
HobbyKing 12A BlueSeries Brushless Speed Controller
Spec.[/b]
Cont. Current:12A[/b]
Burst Current:16A/10sec[/b]
Battery:2-4 Cell Lipo / 5-12 Cell Ni-XX[/b]
SBEC:5V/ 1A Output[/b]
Weight:10g[/b]
Spec.
Capacity:1000mAh
Voltage:3S1P / 3 Cell / 11.1V
Discharge:25C Constant / 35C Burst
Weight:82g
Dimensions:76x15x34mm
Balance Plug:JST-XH
Discharge Plug:XT60
nickatredbox is offline
Contact Us Archive Advertising Cookie Policy
