Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Metal Steering Arm
Reply
Old 04-21-2013, 03:03 PM
jonty
jonty's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Metal Steering Arm
Hi all
I am building a 60 sized plane with an AMT (Fletcher FU24). The AMT is controlled via a 5/32 rod through the fuse. I need to fabricate or buy a linkage to attach to the 5/32 rod to which i can attach the push rod. I was thinking something along the lines of a heavy duty steering arm which has a grub screw. The only thing I can find is the Dubro 155 set up but it is nylon. Will this be ok with the forces on an AMT? If not any idea where I could get a good metal steering arm that is quite long?
jonty is offline
Old 04-22-2013, 05:24 AM
FlyerInOKC
FlyerInOKC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Metal Steering Arm
I think the Dubro arm would work just fine. I have used it and similar arms on .60 to .90 aircraft without any problems.
FlyerInOKC is online now
Old 04-22-2013, 12:26 PM
jonty
jonty's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great - thank you.
jonty is offline
Old 04-22-2013, 01:19 PM
fritzke
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dumas makes metal rudder arms for boats, but they are 1/8 and 3/16.
I'm sure you could drill out the 1/8" to 5/32". I'd be tempted to just make my own
from heavy K&S strip brass and a beefy wheel collar.
Dave
http://www.dumasproducts.com/product...roducts_id=512
http://www.airplanesandrockets.com/a...p-1971-aam.htm
fritzke is offline
Contact Us Archive Advertising Cookie Policy
