Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
First Laser cut Plane
Reply
Old 05-06-2013, 05:10 PM
spyder62
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default First Laser cut Plane
Hi All New here, have been out of the hobby for many years but still have all my old planes and stuff. Besides planes aremy first love so have been following this site for a while and finally signed in.
Have been doing laser cut model Railroad structure kits to pay the bills the last few years. A week a go I had a guy ask if I could cut him some plane parts so had to try one. I found my Jemco Corsair fuselage that I had framed up back in the 80's and the former template drawing I did back them so drew up a fuselage but could not find my wing cores so found a copy of Brian Taylor's Corsair drawings on the net and downloaded them for the wing. To top it all off I did it half size for the Jemco so 27 inch span. Have a test cut built part way up and it will never fly as not much Balsa in stock here so used Basswood for the test. Will add Balsa to my next Balsa USA wood order for the next one.
let me know what you think
Planes.html
rich
rslaserkits
spyder62 is offline
Old 05-06-2013, 05:15 PM
longdan
longdan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: First Laser cut Plane
longdan is offline
Old 05-07-2013, 10:34 AM
BMatthews
Moderator
BMatthews's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As a first try I'd say it looks not to bad. But if you're looking at a flying model at only 27 inch span you're going to want to reduce the amount of wood drastically. Otherwise it'll only be suitable as a shelf display model. But as a skill gaining project for testing your laser cutting it's fine.
The number of fusealge formers is only suitable if the fuselage were going to be planked with sheet. For a stringer and covering design I'd want to see more formers with less spacing between them.
The wing design you show uses a sub leading edge. That's a nice way to do it on a big model but it adds bulk and weight on a small model. Instead what you want is to lose the full sheeting and go for a film or tissue covering option. Part of this change would be to skip the sub leading edge and just end the ribs at a smaller piece of leading edge stock and use a number of small size turbulator spars along with the same number of ribs you show for the rest. The tubulators aids in limiting the sag in the covering at a low weight penalty. And since it would be film/tissue/fabric covered add a regular trailing edge.
As long as the rest was being done the tail surfaces could be switched to built up as well. It doesn't seem like much to gain in the weight loss side of it but that 3 or 4 grams saved in the tail could avoid the need for 9 to 12 grams in the nose. All in all you would stand to save 12 to 16 gms. And on a smaller model of this sort that all adds up fast.
BMatthews is offline
Old 05-07-2013, 11:30 AM
spyder62
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks, Don't plan on flying it as it's just a test. Made it half size as it fit the stock I had on hand and just checking fit. When I make my next wood oder will add the balsa for a full size (54 inch) build . Will sheet this one and see how it looks, then hang from the rafters in the back shop with all the others.
Is a nice change of pace from designing and doing structures in N scale ( 1/160) for model railroads. Might do a Ugly stick or a Funster next. Need parts to fix my Funster anyway just need to find the plans.
rich
spyder62 is offline
Old 05-07-2013, 11:36 AM
FlyerInOKC
FlyerInOKC's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have to agree if all I saw was the wing I would assume I was looking something in a .40 to .60 size airplane. That wing is way over built for a 27" wingspan airplane.
FlyerInOKC is offline
Old 06-04-2013, 10:06 PM
spyder62
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just for the fun of it put it on my postal scale tonight and even with all the basswood weights in at 3.2 OZ and most of that is in the tail. Tail is cut from 1/8 thick basswood so heavy. Balsa is ordered and should be here Friday with luck then will do one in balsa and finish the drawings then if it all fits will scale up to a 48 inch span.rich
spyder62 is offline
Contact Us Archive Advertising Cookie Policy
