Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
wood for fuselage
Reply
Old 08-08-2013, 08:37 PM
ameyam
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default wood for fuselage
Hi,
I am building a 3d airplane similar to a ucd & another similar to funtana60 from free plans. I am custimising them to use materials available locally. The fuselage & bulkheads call for 3mm wood but doesnot specify which type. I am building in cad first so I can work out the bugs. Since i have access to laser cutting, I am going for interlocking construction. The other kit i have so far built (GP US40) had this part in light ply. The LHS has poplar ply in that thickness. They also have model grade ply but its much thicker. What should I use?
Ameyam
ameyam is offline
Old 08-09-2013, 03:27 AM
sensei
sensei's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Use the thinner stuff because 3mm is way overkill as it is and you want to keep it light if you want a great 3D capable airframe. I only use 3/32" thick plywood on my motor boxes with the exception of a 1/4" thick firewall, and fuselage hard points, otherwise I mainly use 3/8" X 3/8" balsa sticks and tri stock as illustrated in these pictures.
Bob
ID:	1906388   Click image for larger version
ID:	1906389   Click image for larger version
sensei is offline
Old 08-09-2013, 06:40 PM
ameyam
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well, there is no thin ply available. So I M going for 3mm balsa. Finishing the cad build with interlocking formers. Lets see..
Ameyam
ameyam is offline
Old 08-09-2013, 06:56 PM
speedracerntrixie
My Feedback: (29)
speedracerntrixie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It's important to use the correct wood for the job at hand. 3mm balsa is not a replacement for 1mm ply in most cases. If you look at Bob's fuse structure you will see that the strength is engineered into the structure and that the motor box, firewall and wing attachments are all ply. Thicker balsa would not be a substitute in these areas. I know that not all materials are redily available everywhere but I know you have been able to order stuff from the states. Take the time to get the proper materials needed.
speedracerntrixie is online now
Old 08-09-2013, 07:13 PM
ameyam
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Actually, not 100% balsa. the firewall and come critical points will be additional layer of birch inside the balsa former but the rest of the fuse and ribs will be ply. I just dont have enough material to build in ply and its madly expensive to import right now
Instead of balsa sticks, I am getting the wood laser cut
Ameyam
File Type: zip
ameyam is offline
Old 08-09-2013, 07:30 PM
ameyam
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Still, If I do decide to use ply, what thickness should it be- 1/8" birch ply or 1/8" poplar? I am asking because I have some 1/16" birch ply lying around, I could use that
Ameyam
ameyam is offline
Old 08-09-2013, 08:36 PM
speedracerntrixie
My Feedback: (29)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking at the plan I don't see much where 1/16 ply could be used. if I were to build that airplane, I would use 1/8" balsa for the fuse sides and 1/8" poplar ply for all the formers and use the 1/16 birch as a doubler front and back of the former at the wing LE but only half way up. I would use 3/16 birch for the firewall.
Old 08-10-2013, 12:47 AM
ameyam
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Speedracer, if you look at all the debris I have left through the modelling procedure, I am planning the fuse sides laser cut as well. All the stuff is 3mm or 1/8" but I need to decide what will be balsa and what ply. If I make the fuse sides of balsa and the bulkhead formers of ply, will that do?
Ameyam
ameyam is offline
Old 08-10-2013, 07:40 AM
sensei
sensei's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ameyam
You could laser cut the 1/16" birch plywood fuselage sides and attach a medium density 3/8" X 3/8" balsa stick frame work to those sides giving you a very strong and lightweight fuselage, but you will need to change your way of thinking and the current model design you posted.
Bob
sensei is offline
Old 08-10-2013, 08:43 PM
ameyam
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi,
I finiashed the cad build yeaterday. I also investiated wood & found a sheet of 1/8" poplar ply I had. Its 12"x36" & weighs 600 odd grams. I think all my fuse could come out from it & since its mostly holes, it should weigh no more with the firewall. I will also use it for the frame in the ailerons, rudder & elevators & sheet over with balsa. For the wings I still need 1/8" balsa. Just the spars are unsourced
I noted the idea to use 1/16" birch with stringers. Only prob, still looking for stringers. Need them for the turtle deck as well
Ameyam
ameyam is offline
Old 08-29-2013, 06:38 AM
chip_MG
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bob,
On a side note, sorry to get off topic but,,
I am glad to see that people are building large plane and from scratch..
I have seen several of your projects here on RCU, very impressive.
I too build but mostly from plans.
Question Bob,
What type of sticks are you using for your fuse as you have shown above??
I have been using poplar I ripped up into 1/4 sq etc, have you used pine b4?
Chip
chip_MG is online now
Old 08-29-2013, 10:41 AM
sensei
sensei's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello Chip,
Thanks for the kind words, I use 3/8" X 3/8" X 48" long medium density balsa I purchase from Specialized Balsa LLC. I then glue it all together with thin and medium CA.
Bob
sensei is offline
Contact Us Archive Advertising Cookie Policy
