Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Coating foam and balsa
Reply
Old 09-07-2013, 01:22 PM
Roger Gray
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lightbulb Coating foam and balsa
I'm building a scratch 8' Otter from plans blown up from a 6' UH kit. This is a float plane only. I'm going to build fuse from pink foam and am considering spray or roller coating with Styrospray1000 coating. Has anyone used this material or another brand to seal foam or balsa for a fuselage? If so what will I need to know. I'd like to coat the entire plane and floats with a light sealing coat and then paint. I am concerned about the weight!
Roger Gray is offline
Reply
Display Modes
