AutoCAD Windows Compatibility
I have been using AutoCAD 14 for many years in different versions of Windows. The latest version is XP. Now, AutoCAD 14 is not compatible with the newer versions of Windows and I understand the Microsoft will no longer be supporting XP due to its difficulty of working with the new versions format. I only need a two dimensional version like AutoCAD LT but I still have my old computer. What are my options? Should I stick it out with my old computer and 14or trash them and go with the latest Windows and LT? Dan
I have the same problem, I am going to hang on to XP till it stops! I am hoping to go to ACAD 2012 and pick up the solid modeling! But I need to go to a newer Microsoft Windows, like double your fun!! HUH!!! My pocket is not that deep!
I just bought a new 'puter with W8 on it. That is another whoooole story........ I downloaded DraftSight and it is fully compatable with W8. I'm told DS has the same commands a ACAD. DS is a free download so to try, is the right price. This comes from somebody that knows less than nothing about CAD. I was sucesfull in using DS to trace over drawings of a Kraft Super Fly and am currently in the (1/4 scale) build mode.
Ken
http://www.rcgroups.com/forums/showthread.php?t=1956662
Ken
Banned
" I am going to hang on to XP till it stops!"
That's what I did, BUT. The last time I had it repaired, and the system re installed, they talked me into installing the 32 bit system, and bye bye my Autocad. Been crying ever since.
Les
Les
Draft sight is supposed to have the same commands as ACAD so the learning curve should be gentle. Free down load so give it a try. Nothing ventured, nothing gained.....
Here we go again..... I have to re-log in to post a reply. I guess back to RCG that works without frustration.
I run ACAD 14 on my Windows 7 Pro machine using Microsoft's free Virtual PC software. Check out Microsoft's Windows XP Mode page, http://windows.microsoft.com/en-us/w...e-in-windows-7 It sets up a virtual computer in software in which you have WinXP and can install and run ACAD14.
ACAD 14 runs just like it should, but I still usually use my older XP machine for ACAD work since it's in my shop/mancave.
Googling "microsoft xp virtual PC" might help, and offers some hope of installing on Windows 8, though I've not tried that.
-Dave
-Dave
Draftsight is a clone of Autocad Lt 2009 as far as my comparison. It uses the exact same commands and short cuts.
I use Autocad 2009 and i can open Draftsight files in Autocad and Autocad 2009 files in Draftsight. They both recognize that you are opening a file that is created by another program but you can edit them easily in you want.
If you use Autocad 14 you should be able to open up all of your Acad 14 files in Draftsight without any problems.
The main difference with Draftsight is it does not have the advance 3d commands of Autocad. It does have the same 3d view commands just not the advanced commands. So it is basically a 2d Cad program that uses the Autocad command structure.
It also has a why smaller footprint than Autocad. You should give it a try, might be perfect for you as it is free. There is also a comprehensive tutorials and a forum on the Draftsight website.
I have a pretty fast machine running W98 that has my copy of ACAD 2000. It is behind the "ultimate firewall" (no connection to the internet, or any network other than temporary cabling to xfr large files) I intend to hold onto it and keep it running until it dies, or I do. Take that, Mr. Gates!
