Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
stephen arko 1/4 scale sport build Question
Reply
Old 10-30-2013, 07:27 AM
rye
My Feedback: (10)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default stephen arko 1/4 scale sport build Question
hi
i am building this plane from plans a stephen akro 1/4 sport scale 75-90 2 stroke or a 80-1304 stroke i needto get about 1-1/2 to 2" more in the cowl area or motor box the fuel tank 16 oz sits in the motor box area and i plan on using a DLE 30 which has a total lenght of 6.37 " where do i start the main frame that is the motor box and wing saddle how and where would i lenght it thanks rye
ID:	1934750   Click image for larger version
ID:	1934751   Click image for larger version
ID:	1934752   Click image for larger version
rye is offline
Old 10-30-2013, 12:22 PM
All Day Dan
All Day Dan's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Rye, Extend the doubler forward the distance you need and enlarge the motor mount surface, the vertical part on the doubler, to fit the DLE. Use 1/8 aircraft plywood for the doubler and at least 1/4 aircraft plywood for the firewall. Epozy the motor mount to the double and use hard wood triangular stock where it meets the doubler. You don't need to make a slot. Leave the wing saddle where it is. Balance the plane to the same CG shown on the plans. Dan.
All Day Dan is online now
Contact Us Archive Advertising Cookie Policy
