Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Corrigated flying surfaces.
Reply
Old 11-26-2013, 09:32 AM
RCdude13
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Corrigated flying surfaces.
How am I going to make all the corrigated surfaces on the Boeing F4B-4 I am building from scratch?
ID:	1942509   Click image for larger version
ID:	1942510   Click image for larger version
ID:	1942511   Click image for larger version
RCdude13 is offline
Old 11-26-2013, 09:49 PM
BMatthews
Moderator
BMatthews's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Carefully and tediously?
What scale are you working to and what would be the scale spacing on the corrugations? Letting us know the size of the issue would aid with appropriate suggestions.
BMatthews is offline
Old 11-27-2013, 03:06 AM
RCdude13
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wink
The corrigations are 1.25" appart on the full size plane. I am building quarter scale. That would make them 5/16" appart. So far the only idea I have is to slice or "rip" wet spagetti in half, lay it on the surface to dry, then glue it after it dries. There must be a better way.
RCdude13 is offline
Old 11-28-2013, 04:29 AM
RCdude13
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I found the answer...Evergreen Plastics half round.
http://www.evergreenscalemodels.com/...m#Half%20Round
RCdude13 is offline
Old 07-05-2014, 06:36 PM
alex5
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
create a plug using the half round,seal it well,then wax it a couple of times...put gelcoat or surface coat on it,let it cure,then layup .75 oz cloth polyester and epoxy(2 layers).Now you have a sheet of the stuff that you can use to reproduce corrugations over and over,using common epoxy techniques.
alex5 is offline
Contact Us Archive Advertising Cookie Policy
