Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Large profile fus fabrication
Reply
Old 12-16-2013, 06:29 AM
dirtybird
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Large profile fus fabrication
I have a couple of wings I built for a Bud Nosen Gere sport that I lost interest in.
I would like to make profile fuselage.for one.
How are they made? Is it two lite plys sandwiched with a foam board between them?
dirtybird is offline
Old 12-16-2013, 07:22 AM
Rodney
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just about anything will work, solid balsa, balsa sheeted with thin plywood, foam with ply skin or ???. Use whatever you have on hand. If glow powered, make sure the front end is substantial and can take the pounding of the internal combustion engine and resulting vibration. If using foam, you may need extra woodwork up front for the glow powered stuff. If electric powered, you can built a little skimpier up front.
Rodney is offline
Old 12-16-2013, 08:09 AM
sensei
sensei's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
+1, Just keep it as light as possible.
Bob
sensei is offline
Old 12-18-2013, 11:35 AM
BMatthews
Moderator
BMatthews's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Two lite ply layers with foam is the heaviest possible way to make it.
If you look at some of the pictures floating around you'll see that a lot of the profile fuselages leave the framing exposed from the mid point of the wing and rearwards and just cover with film. As long as the profile is thick enough this works like a charm. And it's light as well.
BMatthews is offline
Old 12-19-2013, 12:56 PM
yojoelay
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dirtybird,
Have a look at a plane called the Mojo (http://www.swanyshouse.com/index.aspx). The fuse is built around a carbon fibre rod which runs approximately down the thrust line and through the wing root.
Joel
yojoelay is offline
Reply
Display Modes
