Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
servo placment
Reply
Old 01-16-2014, 07:36 AM
69 roadrunner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default servo placment
When building a wing is there a formula to where the servo goes. Like one third of aileron or just as close to wing root as possible. Thanks Steve
69 roadrunner is offline
Old 01-16-2014, 03:51 PM
picard1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bump,
Anybody? I too would like to know !!!
Mike
picard1 is offline
Old 01-16-2014, 07:07 PM
sensei
sensei's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
As a rule I place mine 25 to 30% outboard of the aileron root in a single servo scenario.
Bob
sensei is offline
Old 01-17-2014, 09:32 AM
picard1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Bob!
I have followed several of your threads over the years, Mostly at the other forum sites, LOL. Your willingness to help others and this hobby is greatly appreciated and I know my building skills have improved as a direct result of your work.
Mike
picard1 is offline
Old 01-17-2014, 11:04 AM
BMatthews
Moderator
BMatthews's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've seen references to the idea that you don't want to put the control horn where the inboard and outboard portions are evenly divisible. So don't put the control horn at the 50% point or the 1/3 point. Instead make it an oddball number like 45% or 28%.
The theory being that exactly even or related divisions can promote flutter. Sort of like the old Tacoma suspension bridge. By putting the control horn at some oddball location along the span length you break that possibility.
And of course at that point you put the servo just ahead of the horn if using outboard servos with one on each surface.
To avoid high mass moments in the wing I like to put the servo as inboard as possible within reason. So I look to put the horn at around 27 to 30% out from the inboard end of the surface. That puts the servo out far enough that I don't need to worry as much about flex and I avoid the 4:1 ratio of putting the horn at 25%. But the outboard mounted servo is not so far out that it builds on making the tips heavier too badly.
BMatthews is offline
Old 01-17-2014, 02:00 PM
Rodney
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A good rule of thumb is to place it at an odd multiple of the span; i.e. 1/3, 1/5, 2/5 2/3 etc. This minimizes the chance of flutter as it tends to cancel out some of the possible flutter frequencies. For best use of the forces required of the servo, the farther out on the wing the better.
Rodney is offline
Old 01-17-2014, 03:08 PM
speedracerntrixie
speedracerntrixie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Put the servo wherever it's convenient and keep the linkage tight. Most issues are caused by poor linkage choices or poor mechanical set up.
speedracerntrixie is offline
Old 01-17-2014, 05:51 PM
BMatthews
Moderator
BMatthews's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
1:3 can still set up a strong resonance. 1:4 is better but still possible. 1:5 is better again but still possible. The problem is that you're still using evenly divisible ratios. The higher the ratio the less strong any resonance will be but it can still achieve a size based resonance.
What's needed is a real oddball like 1:3.2. The surface may still flutter but with a non integer based ratio such as this it'll be due to other factors than resonance due to the horn location.
Reply
Display Modes
