Sig Epoxolite replacement
For anyone that has used Sig Epoxolite, the product has been discontinued. I don't know how long it has been gone, but when I was in need of replenishment, I found this out.
After searching the internet and trying a few different sources, I have discovered a suitable replacement.The product is called "P.C.Woody." It is a 2-part, wood-based epoxy filler. It has the same weight and density as Epoxolite but is a little lighter in color; pretty close to a match to balsa wood. It mixes at the same ratio and adheres the same. The only place I have found it is through the Home Depot via special order.
I like to put filets on all the 90 degree surfaces on my planes and with this product, I can continue to do so. Hope this helps any other builders out there.
I mix my own Epoxolite replacement. I use either 5-minute or 30-minute epoxy and brown micro-balloons. You can make it as light as you prefer. Mix the micro-ballons with each part of epoxy separately. Then mix the amount of each part of putty that you need. The more parts mirco-balloons to parts of epoxy the lighter and easier to sand it becomes. Last time I mixed some I had so much micro-balloons that the mixture was lighter than balsa but still very strong.
This is the exact same thing as Epoxolite was except you can make it as light as you light and control the set up time by using 5-minute, 30-minute or 1 hour epoxy.
Ralph White
Ralph White
Terry, Are you using epoxy or polyester finishing resin? The reason I have been using regular epoxy is so I can have it set up in 5 or 30 minutes. I'm sure you are correct in that the finishing resin mixture will sand better. I'll give finishing a try next time.
Ralph
Ralph
There are a lot of modelers that used Epoxolite for years. I'm sure most of them are aware of microballoons and epoxy, but I started this thread to explain that there is now an alternative. If you want to start a microballoons/epoxy thread, feel free to do so. My goal was to inform and help others.
PA
Ralph
I used epoxolite for years until I tried microballoons/epoxy. I couldn't believe how much easier it was to use and incredibly easier to sand while still being more than strong enough for the application.
carl
carl
P C Woody a Sig Epoxolite replacement
Bought some, used it, works great. Thanks for the tip.
Larry
