Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Loaded Dice II Build Thread
Reply
Old 04-23-2015, 08:29 AM
  #51
MTK
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by waynek View Post
Hi Calvin, its a very simple setup with a +/- 12 VDC transformer, fuse, switch and 120VAC dimmer switch. Very close to this:
http://www.charlesriverrc.org/articl...amcutterps.htm
There are lots of designs out there, a quick net search will provide lots of returns.
Yah, re-use those old hockey sticks, eh. W
Aircraft Spruce and Specialty carries an inexpensive 24V transformer (advertised to be used in the Rutan shop) for foam cutting. It also uses a dimmer switch and is similar to Wayne's from what I see. I built mine many years ago now and it still works fine.
The bow on mine is made from a pair of fiberglass rods from Home depot; I'm sure you've seen them- the type that are used for reflectors in yards.
My foam cutter is somewhat hands off based on the fact that any tapered wing planform is a truncated triangle. There is a common center for root and tip arcs for the triangle. Rationing the two is straight forward.
Then using a long stick connected only on one end to the bench. The stick moves down inscribing the triangle in the vertical plane. Connections are made between the stick and the bow wire, the foam husk is located at the proper bench location and the power supply is activated, making a smooth, continuous cut.
FWIW, templates I use are simple firm balsa. Really easy to shape accurately or revise accurately. The edges are lined with sticky back Teflon tape from McMaster Carr. The wire rides along the teflon and simply doesn't stick. The sticky backing works great; the tape is stretched onto each edge and pressed down.
Hopefully someone out there can use these tips to continue the "lost" art of crafting model airplane wings.
MTK is offline
Old 04-23-2015, 09:32 AM
  #52
waynek
waynek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Matt, thanks for that info. Your setup sounds good. Very good in fact. Love to see a photo or better yet a video.
Balsa and sticky back Teflon tape for the templates, I really like that and will try it on my next build.
W
waynek is offline
Old 04-23-2015, 09:39 AM
  #53
waynek
waynek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Matt, is this the tape you are referring to?
http://www.uline.ca/BL_3120/Teflon-Tape?gclsrc=aw.ds
If it works, I'll probably pick some up, but I must say at over $22.00 per roll its a tad on the steep side...
Yah its only Canadian but I get paid in Canadian...
W
waynek is offline
Old 04-24-2015, 04:24 AM
  #54
Calvinman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Matt, I see what you mean on using a pivot and placing the wing or stab at the proper distance from the pivot! I certainly would not of thought of that, I have marked both templates into eights and just eyeballed the cut. I have always used ply for my templates and have had no problems, that being said I have only cut a few wings. I remember reading that when your wire is at the right temperature it will squeal while cutting, does this still hold true? It has been over ten years since I have made foam cores but I would like to cut some for an RCM plans "Rodeo" bi-plane. The Teflon tape looks like it should stop any stutters while cutting also.
Calvi
Calvinman is offline
Old 04-25-2015, 06:31 PM
  #55
waynek
waynek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default More
Gonna do me some gluin'.
So I wear my PPE. As one local guru explained to me, the liver is like a sac, and once its full ( of toxins), its full. Then anytime you get near what its full of, you have trouble. Rash, wheezing, dizziness, nausea, death, etc.
So why take a chance... Keep your liver clean...
Oh and by the way, toxins get absorbed through the skin (and eyes) very effectively. Hence the gloves...
OK, getting off the soapbox now...
Anyway, pic two shows how I ensure my gear will never pull out, not without taking half the wing with it.
W
ID:	2092084   Click image for larger version
waynek is offline
Old 04-25-2015, 06:37 PM
  #56
waynek
waynek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Are we having fun yet?
Yes we are. Having fun that is.
More views of those mini-ribs to reinforce the LG plates. I think they're called scabs. Someone please chime in and let us know.
BTW, like most things in this thread, not my idea, handed down to me by awesome dudes giving their time to show me the ropes.
Just passing it along...
Hope you're enjoying.
W
ID:	2092094   Click image for larger version
ID:	2092095   Click image for larger version
waynek is offline
Old 04-28-2015, 04:58 PM
  #57
waynek
waynek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It will need servos in the wings.
W
ID:	2092889   Click image for larger version
waynek is offline
Old 04-28-2015, 05:04 PM
  #58
waynek
waynek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Needed to fabricate something to melt the servo cutout in the wing. One for each side. Seemed to turn out OK. I've seen guys using the trigger-operated soldering guns (like my dad had when I was a kid) for this to very good effect also.
W
ID:	2092891   Click image for larger version
ID:	2092892   Click image for larger version
waynek is offline
Old 10-08-2015, 01:24 PM
  #59
waynek
waynek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Got some wing sheeting done
The horizontal stabs and wings turned out OK.
I use water-base contact cement for the core to wing-skin adhesive. Apply the glue to the foam first because it takes a lot longer to become tacky. Once glue is applied to both surfaces and pretty much dry, carefully position the skin over the core and smooth down. Then back into the foam shucks (sp?) with much weight to keep things together and true.
Lots of tutorials on this all over the net with good variety in successful techniques.
W
ID:	2124429   Click image for larger version
ID:	2124430   Click image for larger version
waynek is offline
Old 10-08-2015, 01:27 PM
  #60
waynek
waynek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default The Wings
Also not too bad.
W
ID:	2124432   Click image for larger version
ID:	2124433   Click image for larger version
waynek is offline
Old 10-08-2015, 01:29 PM
  #61
waynek
waynek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Wing
Last one on the wings for now.
W
waynek is offline
Old 03-21-2016, 09:00 AM
  #62
waynek
waynek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Canopy
I just received a canopy from Park Flyer Plastics. Great quality, great service, fair prices. Highly recommended.
Anyway, they didn't have exactly what I needed so I bought their Chipmunk Canopy and its very close.
I also pulled the fuse down from the rafters - forgot how looong it is.
After a cross Canada move and a couple of other builds, this bird is now back on the table. Sorry for the delay for those that were following...
W
ID:	2153478   Click image for larger version
waynek is offline
Old 03-21-2016, 10:17 AM
  #63
Calvinman
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Good to see ya back at it Wayne!
Old 05-22-2019, 11:22 AM
  #64
jonnyjr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It appears Wayne never finished this which is a shame as I am building the same at the moment. If your still around Wayne it would be great to hear how you got on with this build!
jonnyjr is offline
