Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Scratch build "Bertha"
Old 02-20-2015, 08:14 PM
sensei
sensei's Avatar
Thanks Jim,
Bob
Old 02-21-2015, 06:09 AM
jimmba
Default Mock up time
Well , almost anyways.... Didnt put motor on . Shes no skinny girl ! ( hence the name "Bertha" : )
ID:	2075091   Click image for larger version
Old 02-25-2015, 04:41 PM
jimmba
I had some aluminum plate laying around ... So Bertha has a tailwheel assy now!😛
ID:	2076463   Click image for larger version
ID:	2076464   Click image for larger version
Old 03-01-2015, 06:52 AM
jimmba
After attaching the tailwheel assy to fuse ( pic attached) I mounted motor and piled remaining bits in fuse ( servos , battery , etc then weighed again . Ready to cover she's at 33 lbs . I'm wondering if I should set the zenoah g62 aside and put the DA 100 I have on her !? Have to make a new cowl if I do . I would drop almost two lbs in motor weight and gain almost 4 hp. What would you all do?
Old 03-01-2015, 07:36 PM
sensei
sensei's Avatar
A DA 100 is heavier than a G-62 so I don't see how you will be almost 2 lbs. lighter by swapping engines.
Bob
Old 03-02-2015, 07:26 AM
  #31
jimmba
Hey Bob, my g62 is mag fired and has the recoil spring start. It weighs 6 lbs on my postage scale. My Da100 weighs 4.25 lbs but as I typed this reply I realized I didnt weigh the stock headers or electronic ignition. So weights are going to be very close to same I guess. Ouch , I just thought of battery for Da ignition ! Well Bob , at my age I can claim another " senior moment " ( egg on face appropiate here! ) . I've never used these large motors before , they've only sat on my shelves!
So , I really wouldnt be gaining anything but " grunt" eh?
Old 03-02-2015, 06:06 PM
  #32
jimmba
No comments / thoughts on using the Da vs the G62?
Old 03-02-2015, 06:40 PM
  #33
sensei
sensei's Avatar
I think for this type of airframe I would stick with the G-62, that would just be my personal preference.
Bob
Old 03-06-2015, 03:57 PM
  #34
jimmba
B Matthews , what would you think of hoerner wingtips added to Bertha? , aside from the added 16" to wingspan that is . I've attached a pic of a roughed out shape .
ID:	2079378   Click image for larger version
Old 03-07-2015, 07:50 AM
  #35
jimmba
Anyone have thoughts on using hoerner tips on Bertha?
Old 03-08-2015, 05:00 PM
  #36
jimmba
No one ❓ love it hate or otherwise ❓c'mon Mr Matthews get the ball rolling on this "hoerner " wingtip question. Some dang body needs to tell me no and some other dang body cheer me on ��
Dont be skeered ❗Im a old fart thats just having fun wading off into new fields , not gonna hurt my feelings ��
Old 03-09-2015, 02:27 AM
  #37
sensei
sensei's Avatar
They will look and work real fine on your application.
Bob
Old 03-09-2015, 06:32 PM
  #38
jimmba
Bob , you are a kindly soul ❗you must be to reply to a old man thats attempting to stir up some " out of the box " aerodynamic folderol discussion.
So ..... While youre so inclined ..... What would you think of some vg 's all along those purty wings❓
Old 03-09-2015, 06:53 PM
  #39
sensei
sensei's Avatar
You can certainly place them, but to be honest... I don't think you need them.
Bob
Old 03-10-2015, 07:05 AM
  #40
jimmba
Hmmmmm, I really want it to slow way down for landing , but to also retain a lot of control at slow speed . After reading one modelers experience with a 1/3 scale super cub using ultralight vg's from Aircraft Spruce I got all hot and bothered to use them. I guess BMatthews advice on the airfoil has me more worried than I realized.
Old 03-11-2015, 03:39 AM
  #41
sensei
sensei's Avatar
Well you started with 2508 sq.in. of wing area, then added the wing tips giving you now 2812 of wing area, this is all working in your favor.
Bob
