Jetfire 20 plans
Jetfire 20 plans
I am looking for the plans for the Airtronics Jetfire 20. I have a fuse sitting on the shelf but that is all. Any help would be appreciated.
Thanks.
Buzz.
Thanks.
Buzz.
I have a NIB kit of the Jetfire 20, not sure if the plans have any patterns on them. I can check and make you a copy if they will help. You might also check the Outerzone site, they have a lot of out of production plans available for free download.
Thank you good Sir. I would really really appreciate that. If memory serves, the ribs were the same all the way across.
Let me know the cost.
Thanks.
Buzz.
Thanks.
Buzz.
Got a chance to look over the plans. Most of the ribs are identical, couple that are a bit different at the center section. Will try to get them copied for you this weekend. Can you message me your address?
Thank you for all the help John. I have them down and printed, taped together right now. I was working on the garage a little this weekend. Was smokin hot out there so I did not get much done. I am to old and crippled to hang out in 108 degrees cleaning up the shop. Next couple of weekends will be cooler so I will get more done.
Buzz.
Buzz.
