Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
larger version of Miss 2 with ailerons - dihedral ?
Reply
Old 03-22-2016, 03:56 AM
Brunox
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default larger version of Miss 2 with ailerons - dihedral ?
Hi, after having built the Miss 2 from Hobby Lobby, I decided to enlarge the plans to 135% and start a scratch building, including ailerons on the wing.
The wing is now nearly finished but I realize the dihedral is only 4 degrees (I expected 6 degrees at least) and I'm afraid this may be unsufficient for this plane. It is supposed to be a very gentle and forgiving flyer... Could anyone provide some advice ?
Bruno
Name:	photo Wing 2.JPG
ID:	2153693   Click image for larger version
Name:	photo wing 1.JPG
Brunox is offline
Old 03-22-2016, 05:33 AM
ron ward
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what doe the plans call for ?. the reason I ask is that tat you really shouldn't have to increase the angle, just because you increased the size of the plane. simply put, 4 degrees at 4 feet is four degrees at 6 feet as well and will have the same effect on stability in either size. if the original size plans called for 4 degrees the plane will respond the same way to the same degree of dihedral when increased in size.
ron ward is offline
Old 03-22-2016, 06:27 AM
Brunox
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In fact the original plane (picture below) does not have ailerons and has a double dihedral in the wing... I wanted to have 6 degrees but after gluing the right and left pieces of the wing it has only 4. One option would be to cut the center section of the wing and to increase the dihedral but it will be hard to do since I used epoxy...
Name:	photo Miss 2 août 2015  (10).JPG
Brunox is offline
Old 03-22-2016, 06:34 AM
Rodney
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
With ailerons, your present dihedral is plenty. It is only when you do not have ailerons that you need dihedral. In fact, many planes designed with ailerons eliminate the dihedral entirely to eliminate the undesirable effect of having yaw coupling as the ailerons are activated.
Rodney is offline
Old 03-22-2016, 09:30 AM
BMatthews
BMatthews's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It'll be just fine. As mentioned the ailerons take the place of the dihedral.
It's a good thing that you took out the tip dihedral. I've read a fair number of reports that lots of dihedral does not play well when combined with ailerons.
BMatthews is offline
Old 03-23-2016, 05:10 AM
Brunox
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you for your answers ! So I put my saw aside and leave the wing as is... and go on with the tail and fuselage...
Brunox is offline
