Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Airbus A321 scratch build
Reply
Old 04-24-2016, 11:00 AM
Anderl7890
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Airbus A321 scratch build
Hi guys,
a few years ago i started a scratch build of an Airbus A321. After being really enthusiastic with this project, i lost my motivation with a pc harddrive crash, where i lost all my CAD data.
The wing was nearly finished, but all my data concerning the wing construction and the aircraft nose was lost. Well, luckily, due to my job i have access to the manufacturers manuals.
And now i decided to finish this litte project. I'm curious if it flies.
And here are the specs.:
Span: 61"
Lenght: 76"
Weight (at least i hope): 5,7lb
Propulsion: 2x Wemotec MiniFan (5 blade classic) with HET 2W Motor on 3S lipo
Gear: E-Flite 15-25 Retracts
Every couple of days i will post a pic until i reach the current state of the build.
Let's start with the wing:
The airfoil is a SG6040 at the root going to a CLARK Y at the tip.
Regards
Andi
Name:	A321 wing1.jpg
Anderl7890 is offline
Old 04-25-2016, 04:08 AM
Anderl7890
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here we go:
Wing halves joined, part of the sheeting applied and also pylon and engine attachments completed.
The engine pylons and nacelles are attached by two screws in aluminum bushes. The ESCs are located in the wing leading edge (not installed yet). The pros and cons of this Installation: Short wiring from battery to ESC to motor. But poor cooling of ESC. I'm not going to cut cooling orifices into the wing. Looks aweful.
Regards
Andi
Name:	A321 wing2.jpg
ID:	2158989   Click image for larger version
Name:	A321 wing3.jpg
Old 04-26-2016, 03:51 AM
Anderl7890
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Installation of main retracts
Regards
Name:	A321 wing4.jpg
Old 04-27-2016, 06:34 AM
Anderl7890
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
And here the finshed wing.
All thats missing is the wing tip fence.
Regards
Name:	A321 wing5.jpg
Old 04-27-2016, 01:18 PM
gutmark
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks good!
gutmark is offline
Old 04-28-2016, 06:02 AM
gutmark
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Were you able to recover your original plans or are you working from tech order drawings? You have some skills!
gutmark is offline
Old 04-28-2016, 07:40 AM
Anderl7890
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi
No, all my original plans and drawings are lost since everything was done in CAD.
I have to repeat the complete CAD construction. For most parts i use original Airbus CAD drawings that can be downloaded from Airbus http://www.airbus.com/support/mainte...rbus-aircraft/
For special parts like frames in the cockpit and fwd fuselage area i have some drawings from the original frames.
And some parts i do on my own.
For example the engine nacelles.
My A321 Modell is equipped with "IAE V2533 Engines", that makes the nacelle construction a litte easier.
Here's how i do it:
First, i make drawings in CAD. For that i use a simple to use CAD Programm called "Darft Board Pocket". It's in 2D:
Note that my nacelles are simplyfied. Different to mine, the real V2500 engine nacelle is not a perfect circle in shape. Actually its slightly oval a little bit thicker at the very bottom. But at a scale of 1:23 this is hardly visible. So why waste a lot of time and "brainpower" in creating something you cannot see? What is important with the nacelles is that the inlet has an angle of 6 when viewed from the side. This is an eyecatcher an much more important than the oval shape.
When finished, i order the parts from a milling service, and simply put everyhing together. Somthimes it feels like a kit.
Regards
Andi
ID:	2159722   Click image for larger version
ID:	2159723   Click image for larger version
Old 04-28-2016, 08:25 AM
gutmark
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice!
gutmark is offline
Old 04-29-2016, 02:38 AM
fumus
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice project!
Another A321 with IAE nacelles can be found here: http://rauch-airliner.com/A320E.htm
fumus is offline
Old 05-03-2016, 10:41 PM
Anderl7890
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi
Yes you are right. I also know the Rauch Airliners. But they have two problems in common. Too big in size (for a 106" fuselage i would need a trailer) and too much wing loading.
My construction is more transport and trunk friendly and my wing loading is also less. I hope it flies.
Let's go to the fuselage:
The fuselage of the A320 Family aircraft is not circular shaped. It's a double bubble! Like most airliners.
The Diameter of the first upper bubble is 3950mm and the diameter of the lower one is 3852mm. Their centers are 240mm apart, which gives roughly an oval shape. In my models size fuselage height is 176,5mm width is 169mm.
I decided to build the fuse out of a foam construction that later will be covered by some glass plies to get a hard and smooth surface.
Only for the nose gear and the later wing attachments there a plywood frames.
Here's the nose retract Installation including steering servo.
The fuselage tail cost me some headache. After trashing the idea of building a classic plywood construction, i decided to use foam too. To get a roughly correct shape i cut the foam in sections by use of plywood Formers as guidance.
The plywood Formers had been removed from the tail construction bevore glueing everything together.
The tail, of course, needs some sanding and shaping before finished..
Regards
Andi
Name:	A321 fuse1.jpg
ID:	2160760   Click image for larger version
Name:	A321 fuse2.jpg
ID:	2160761   Click image for larger version
Name:	A321 fuse3.jpg
ID:	2160762   Click image for larger version
Name:	A321 fuse4.jpg
Old 05-04-2016, 05:24 AM
gutmark
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I like your construction methods - everything looks so clean and simple...
gutmark is offline
Old 05-09-2016, 12:26 PM
Anderl7890
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi
After application of some putty (i use the white very light filler from hobbylite) and some sanding, the fuselage tail looks much better now.
Now ist time to install the wooden horizontal and vertical stabilizers.
Therefore i had to make some cutout. Looks much nastier as it really is.
Before i can close this cutout again. I need to install the rudder Torsion link.
And before i can install the rudder torsion link, i have to get access into the fuselage. For Installation of the wings, i have to make a larger cutout, which also serves as Access to servos and Receiver.
And this cutout is covered by the bellyfairing.
To get erverything straight again:
1st: Build wing sattle and bellyfairing
2nd: Install servos for Elevator and rudder and install rudder Torsion linkage.
3rd: Close cutout for empenage on tailsection.
Ok, lets get started.
Today i made a rough cut of the bellyfairing.
The wing incidence is also included in it.
Regards
Andi
Name:	A321 Fuse tail1.jpg
ID:	2161770   Click image for larger version
Name:	A321 Fuse tail2.jpg
ID:	2161771   Click image for larger version
ID:	2161773   Click image for larger version
Old 05-11-2016, 04:50 AM
gutmark
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Any more progress?
gutmark is offline
Old 05-23-2016, 06:26 AM
gutmark
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Andi - Any more pictures?
gutmark is offline
Old 05-24-2016, 05:15 AM
Anderl7890
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More pics are coming soon.
Just didn't find enough time to continue...
Old 05-27-2016, 02:50 PM
Anderl7890
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I made some Progress with the belly fairing.
After some sanding it Looks like this:
Regards
Andi
Name:	Belly Fairing 11.jpg
ID:	2164445   Click image for larger version
Name:	Belly Fairing 12.jpg
Old 09-22-2016, 04:13 AM
Anderl7890
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi all,
yes i know it has been a while. Lack of time.
Unfortunately the engine nacells came out to be too heavy, making the whole plane extremely nose heavy. Since i had no idea how to change that (a tail installed battery is no option due to bad access) i decided to design new engine cowls. More lightweight ones. After some consideration i decided to build them much more closer to the real ones.
And thats what came out.
The upper one is the old heavy design. The lower one is the new one. The Fan unit is the same.
This new nacelle is 50grams lighter than the old one. Saving 100grams on a 2600grams airplane is a lot.
The sheeting is CAD design, too. The small one's for the inlet. The large on for the exterior.
Inlet complete. Simply glued in.
Best regards.
ID:	2182512   Click image for larger version
ID:	2182513   Click image for larger version
ID:	2182514   Click image for larger version
Old 11-02-2016, 07:11 AM
Anderl7890
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Time to build the most important part.
The Airliners nose.
You can build a perfect plane, but when its nose isn't correct, the complete plane Looks wrong somehow. Especially when we talk about airliners.
Here we go:
Cockpit Formers.
Sheeted with Balsa and roughly formed Balsa radome.
Sanded after some putty application.
Best regards
Andi
ID:	2188574   Click image for larger version
Name:	Nose rough.jpg
ID:	2188575   Click image for larger version
Name:	nose sanded 3.jpg
ID:	2188576   Click image for larger version
Name:	nose sanded1.jpg
ID:	2188577   Click image for larger version
Name:	nose sanded2.jpg
Old 11-09-2016, 09:36 AM
H5606
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wonderful workmanship and attention to detail - enjoyed seeing how wing center section, nacelles, and nose construction challenges are addressed - thanks for documenting and sharing.
H5606 is offline
Old 11-15-2016, 04:59 AM
Anderl7890
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi all,
The first of the engines ist finished. Except covering of course. When looking at the pictures i start to wonder how to get the inlet covered.
Maybe it is interesting to notice that the fan unit is not removeable anymore. I can maybe with some luck change the motor. But im not sure about the fan rotor. The fan rotor diameter is 69mm. On the contrary the inlet diameter is only 64mm. The diffusor shape of the inlet (like on the original engine) is the cause for that.
That means, if the fan unit gets damaged, i need to build a complete new engine like seen on the pictures.
Another detail concerning flight control. The Eagle Tree Guardian supports some flight envelope features like on the real Airbus A321. For example: duch roll damping with the rudder, turn coordination, bank angle and pitch angle protection and flight characteristics like on an advanced fly by wire airliner. Of course some adjustment flights might be necessary.
As you see, i am not just trying to pattern the look, i also try to get as close to the real things flight characteristics as possible.
Best regards
Andi
ID:	2190047   Click image for larger version
ID:	2190048   Click image for larger version
ID:	2190049   Click image for larger version
Old 03-21-2019, 01:43 PM
cajunken1949
Default Request for Info
You say you have access to Airbus (A321) Manuals. Do they quote wing root incidence angle, wing twist angles, show diagrams of airfoils used (or airfoil section designators), wing and horizontal tail dihedral angles, wing/tail/fin drawings, connection points in fuselage and wing of landing gear, ...? Are they online, and if so, what is their web address?
cajunken1949 is offline
