Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Painting Depron
Old 04-25-2017, 02:28 PM
cakeman68
Default Painting Depron
Hello group, newbie to model building here. I have built me first plane out of depron foam. I was told that before I paint it that I needed to wipe it down with alcohol before painting as this will remove all of the oil and such from the form. I have done that and now that I am painting it, I have purchased tempera paint and when I attempt to paint it, all of the paint will streak and disappear like oil and water. What am I doing wrong. I have also purchased spray paint frpm the local craft store and this is not working either. Thank you for any suggestions.
Old 04-26-2017, 04:42 AM
rgburrill
rgburrill's Avatar
Did you prime it?
Old 04-29-2017, 09:01 AM
cakeman68
Yes I have and the paint still streaks
Old 05-08-2017, 01:24 PM
Lownverted
Lownverted's Avatar
You don't need to prime it. Tempra paint doesn't work very well. I had the best luck with Krylon Shot Cuts or Tamiya paint. Multiple light coats are you friend.
