Go Back  RCU Forums > RC Airplanes > Scratch Building, Aircraft Design, 3D/CAD
Reload this Page >
Nitro Foamie design overview
Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Old 07-21-2018, 06:56 AM
Dave Wave
Default Nitro Foamie design overview
I am considering scratch building a .40 nitro powered twin.
I am looking to build a relativity fast aircraft, so I need a fairly light and rigid structure.
I would like to build out of sheet foam insulation. I was planning a wire cut wing with a square CF full length spar.
Tail will be sheet balsa, foam on a CF rod.
My question is what sort of build, covering, reinforcement method can be used to ensure that the wing and fuselage do not flutter under the anticipated high speed?
Can monocoat be used to stiffen the structure?
Dave
