Hobbico Hobbistar 60
Hi I'm trying to build a 60 hobbistar of Hobbico a friend broke his and copy the pieces and draw the plans but someone knows what incidence the wing and the engine carries? Thanks in avance from Maracaibo Venezuela
Here is the manual for the HOBBISTAR 60. Unfortunately I don’t see the answer to your questions. As an ARF, it may just be built into the airframe. The manual will help in the rebuild. Hope this helps and good luck.
Saludos
Saludos
