Reverse dihedral in foam wing
CA
Hi. I recently bought a foam cutter and have been trying to cut some foam wings. I keep having this problem where the wing turns out having a reverse dihedral type bow in it. Anyone else have this problem, and if so how do you fix it? Thanks
RE: Reverse dihedral in foam wing
Ryan:
Not uncommon. One of the big reasons you need to save the shucks. Make a sandwich of the cores, sheeting and shucks. As the glue dries for the sheeting put a flat board on top of the sandwich and weight it down fairly heavily - it'll come out straight and you'll have no problem.
Bill.
Bill.
