Go Back  RCU Forums > RC Airplanes > Scratch Building, Aircraft Design, 3D/CAD
Reload this Page >
PLANK!! It's big, bad, foam, and tail-less!!
Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Old 11-08-2003, 01:31 PM
CrazyHerb
CrazyHerb's Avatar
Default PLANK!! It's big, bad, foam, and tail-less!!
Here's my next ambition....
Scroll down to check it...
Drew up the plans today...airframe made from Owens Corning Foamular 250 1.5 inch thick PINK FOAM.
http://home.comcast.net/~crazyherb-rc/
Ryobi Twin-ring conversion 31cc
76 in span
23.5 in chord
HUGE rudder
This brings me to my next question....what's the largest model that you've HAND LAUNCHED before??
I'm thinking of installing on-board kill switch for belly landing (ala Lanier Shrike).
Maybe temp gear for maiden flight (make sure it's trimmed)....then under-hand launch style.
High Res .jpg available here on my page...scroll down to the bottom when you get there...turn up your volume and enjoy the banner I made too...hehehe
What ya'll think??? Ambitious enough???
My driving factors are:
1. To make a simple, super light airframe to prove a "Ryobi CAN HOVER".
2. To make a wing that will flat-spin like a mad (maybe even climb in one)
3. Less than 50 bux for materials for the airframe.
4. And the biggie.... Turn lots of heads at the field... "What the ____ is that!?"
CrazyHerb
Old 11-08-2003, 01:57 PM
CrazyHerb
CrazyHerb's Avatar
Default RE: PLANK!! It's big, bad, foam, and tail-less!!
Parts are cut!
http://home.comcast.net/~crazyherb-rc/plankparts.jpg
Old 11-08-2003, 07:39 PM
William Robison
Steve:
You surely do live up to your name!
I've seen much larger hand launched, but it had one man on each wing, and a third holding the tail. Can you say "One, Two, Three, Heave!!?"
Bill.
Old 11-09-2003, 12:06 AM
Tall Paul
I made a scaled up SIG "Wonder" using a Stik wing.. something like a 60 inch span. Handlaunched it ONCE! Scared me! Added a landing gear ASAP!
Old 11-09-2003, 02:14 AM
CrazyHerb
CrazyHerb's Avatar
Construction Page
http://home.comcast.net/~sherbertson/
