GP Super Sportster Airfoil
AZ
RE: GP Super Sportster Airfoil
Don't know what specific airfoil it is, but its a thickish symetrical airfoil with a soft leading edge. Yields very nice flight characteristics. I've used it on a couple of different planes with great success. For my $.02 worth, The Sportster is one of the best flying sport planes to ever come along, and the airfoil is a large part of its success.
FL,
Well, my curiosity got the best of me, and I e-mailed Great Planes and asked them. Here is their reply.
"The airfoil for the Super Sportster does not have a specific number or
designation. The airfoil was one of the model airfoils at the time that
was known to work well in this particular design."
I received a Super Sportster .40 fuselage that a friend had. He had crashed it many years ago and never rebuilt it. He did not know what happened to the wing. The fuselage was not damage badly. I have repaired and recovered it, and now I just need a wing. I have a hot wire setup for cutting foam cores, but I need the airfoil so I can make some templates. Does anyone have the airfoil for the Super Sportster as an image or in a .dwg format?
ON, CANADA
I have the plans for the Mk.I Super Sportster 40. I believe it's the same airfoil as the Mk.II. I'll scan and post a rib tonight after work. Stay tuned...
Juice
Juice
ON, CANADA
The scanner is broken... sorry. Here's a picture of the airfoil, taken directly over the wing rib. I measure 10-1/8" from LE to TE. It's a constant chord wing, so all ribs are the same.
I don't kow if you should trust these pictures to make your ribs, because they may have been taken at a very slight angle, no matter how hard I tried to get them squared up. Use them at your own risk. At least you have an idea of what they look like. When the scanner is fixed I can post again.
I hope I helped.
Juice
I hope I helped.
Juice
TN
Looks like an NACA0015 matches pretty close! Here's a pic:
Click on the little gizmo at tyhe bottom RHS of the pic for full size.
Community Moderators
My Feedback: (42)
ORIGINAL: Railridr
John
