Free
RE: Free
There are numerous ones out there on a free basis. Go to www.cadalog.com and they have several for download. They also have direct links to most of the CAD manufacturers where you can again view what is being offered. Each one is a bit different, and set up to view native file formats best. A few will not let you print out in the un-paid, test modes.
Wm.
Wm.
RE: Free
Hi
If you go to the Autodesk web site at www.autodesk.com you will be able to download the free Autodesk Express Viewer.
The funtionality is limited but it will allow you to view and print dwg and dxf files.
Good luck
Good luck
RE: Free
Hi, you can view and manipulate Cad files with CorelDraw and Adobe Illustrator, you only need to import the file from DWG or DXf option, and again, after you change or manipulate the file (resize or modify or any else), you can save the drawing like an Autocad File, by the export menu.
Raul
Raul
