Need Advice on finding CG
TN
When you are measuring a wing to do CG calculations do you include the area of the flaps and ailerons or do you only measure the fixed area of the wing structure?
RE: Need Advice on finding CG
Everything you can see in a plan view, including area inside the fuselage on logical extensions of the leading and trailing edges and any area in nacelles as with a fuselage..
