Aileron linkage
RE: Aileron linkage
I believe Dubro has what you want. It is a ball that you mount on your servo arm. You also get a socket with threaded ends on both sides. Makes hooking up ailerons simple. I think that they are only good for up to say a 60 size plane though. Take a look at tower or dubro's web site and see what's out there.
Mark Shuman
Mark Shuman
Banned
RE: Aileron linkage
Easiest way... go to Tower hobbies.. download the instruction book for a "Sig Four-Star 40" Look how its done. (same in a bunch of trainers...)
That is the EASIEST.
FL
RE: Aileron linkage
We don't really have enough information to answer. Do you have strip ailerons where they both extend in to the fuselage side, or outboard ailerons where they are only out by the tip, like full scale?
