vacuum forming
vacuum forming
I´m about to start a new scratch project. a pillan t-35 of 80".
this two seat low wing trainer has a big canopy as the t-34 mentor. who could do the vacuum forming fro the canopy??
Do you know who and "how much"??
I guess I would send the wood or foam plug.
Tato.
Tato.
RE: vacuum forming
Vacuuforming is easy to do yourself. You make a wood box with a perforated top, hook it up to your shop vacuum, and heat the plastic in your oven.
There are lots of small details, but RCM has a book on how to do it. Also, there are advertisements for DIY vacuuformers and books in some of the magazines.
RE: vacuum forming
Design Man-also interested in making a canopy, somewhat familiar with vacuum forming on an Industrial scale, is it too complicated to add a few more details on the perforated box and what type of plastic sheeting you use. I basically wondered how to seal the box so as to get a vacuum pull on the sheeting. Flipstart
RE: vacuum forming
ORIGINAL: flipstart
RE: vacuum forming
Thanks for the info-sounds doable-is there a link showing further details on vacuum forming and some of the dos and don'ts and etc. Flipstart
GA
RE: vacuum forming
K&S engineering makes the plastic you would use in 9x12 sheets available on Tower Hobbies site. And if your too lazy(like me) to make the box...http://www.warmplastic.com/
RE: vacuum forming
Ok...I get the idea about the box with the holes in the top and you set your plug of what you want to make but I seem to be lost as to what to make the frame out of that sandwiches the plastic.
RE: vacuum forming
I found a very good web site for making everything needed to vacuum form box and almost anything else you may need, very informative web site.
Banned
RE: vacuum forming
The frame can be made of wood... or metal. wood is more often used for home vacu-form boxes. Screw and glue the corners to make sure its rigid.
some people witll put weather-strip of some sort on the edges of the upper frame... to aid in getting a good FAST pull-down.
RE: vacuum forming
That's good info...I have always wanted to learn how to do the vacuum forming procedure but fo some reason shyed away from it...little did I know how easy and painless it is...
How about a how-to on plugs?
Great info about vacuum forming! Is there any info available for creating plugs, such as, materials that can be used etc.?
Thanks in advance.
Chuck
Thanks in advance.
Chuck
RE: How about a how-to on plugs?
Chuck...from what I could tell wood plugs seemed to be the all around favorite for small to medium runs. I also read where plugs were made from plaster paris. I think what I will do is build a center rib the shape of the canopy outline looking at it from the side, glue it in the center of the canopy section and use styrofoam block glued in on each side of the balsa templete. Next sand the foam down to the shape needed the glass over it with 2 oz. cloth and finish resin. Get it as smooth possiblethen remove it from the fuse. Next I will build a 1/2" base for it to sit on the vacuum table. From what I have read making canopies and cowls is very easy ...I plan to build my set up this weekend...I have an old speaker box that is perfect.
My Feedback: (60)
AZ
RE: vacuum forming
Guys, here's a link to a short tutorial I posted on vac forming right here on RCU: http://www.rcuniverse.com/forum/m_81..._1/key_/tm.htm
I'm by no means an expert but the response to my post was good and many people chimed in with more tips and techniques. It may be of some use to you gentleman.
FL
RE: vacuum forming
If you need a heating elemant to make a dedicated plastic heater for your shop you can get a replacement element for an electric smoker - which will be a bit bigger than a foot square, for about $30. Look here:
http://www.thebrinkmanncorp.com/acb/...ID=106&CATID=6
RE: vacuum forming
Thanks for all the help guys...I just can't beleive that I waited so long to do this...lazy I guess. It sure makes things a lot easier because I di a lot of scratch building...I will be making a plug and the vacuum box this weekend.
RE: vacuum forming
I only need few large plastic sheets.
I read balsa USA has such item.
498 .030 x 24" Wide per foot $3.50
any other place to buy at least 12" x24" size clear plastic vacuum form sheet?
Banned
RE: vacuum forming
I have used a friends vacuum former, and boy it really works well. One drawback of making the plugs out of wood is the grain will show up in the plastic. Plaster works really well. Just remember that any slight bump or ding on your plug will be in your finished product. We used foam to make the shape first, then made a mold from the foam plug. Last we cast the plaster plug and used this to make the canopy. It is a lot of work for just one part, but I got a lot of satisfaction knowing that I made it myself. Just my $.02 worth.
RE: vacuum forming
you could make a foam or wood plug, then coat the outside with some type
of resin or paint and sand it smooth and may be another coat of paint.
epoxy should work just fine.
just make sure the paint isn't the type that will stick to the vacuum form plastic sheet.
