Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
monocoat help
Old 04-13-2004, 08:13 AM
mhmitchell
Default monocoat help
I am going to use a two tone coloring scheme on my next aircraft. The leading edge will be monocoat over the balse covering. The rest is open bay and will be a different color. How do I accomplish this with as straight lines as possible.
Do I cover the whole wing and treat the leading edge as trim and place that color over the wing color or id there some way I can sort of but the two colors together?
Old 04-15-2004, 09:35 AM
ptulmer
ptulmer's Avatar
Default RE: monocoat help
The LE should be the last piece you do. No edges in the wind if possible. And overlap the pieces a little. That's just how I do it.
Old 04-15-2004, 09:58 AM
mhmitchell
Thanks I thought that was the way to do it!
